08-05-2023, 09:56 AM | #1 |
Nibbi pwk 26mm
Hello, I got myself a Nibbi pwk26 for my boom Vader 125, I was checking the carb out and realized I can’t use my cable Choke from my handle bars so do they sell any attachments so I can use my cable Choke with this carb? Thanks
08-07-2023, 07:34 PM | #2 |
AFAIK, the only "choke" on a Nibbi (It's technically not a choke - it's an enrichener circuit.) is activated by pulling up on that knob on the left side of the carburetor. I've never encountered any "cable attachment" device on a Nibbi. A nearly identical system can be found on some Mikuni carbs.
08-08-2023, 07:50 AM | #3 |
I used this cable adapter. https://www.ebay.com/itm/20438003642...3ABFBMuOnVz7pi
