Old 06-19-2023, 08:21 AM   #1
Bill Hilly   Bill Hilly is offline
How long to expect stock TBR7 rear tire to last ?
I will be needing to replace my rear tire on my TBR7 pretty soon due to it being nearly worn down to the indicator strips. These bikes come with more if a 50/50 tread, rather than Knobby, so I am surprised that it's worn so bad . The bike is showing almost 3,500 on the stock odometer, which would be about 2,500 miles. I thought that they were supposed to be good for a lot more miles. How long do most of these type rear tires normally last under normal use ?
Old 06-19-2023, 01:44 PM   #2
These cheap tires aren't known for their longevity. 4 to 6k miles sounds about right for a rear.
Old 06-19-2023, 02:35 PM   #3
Mine is not quite down to the indicator strips, but I figure by the time it reads 4,000 on the odometer, it will be. The thing is the odometer registers in kilometers per hour.
Old 06-19-2023, 02:55 PM   #4
buzz   buzz is online now
Megadan is right,cheap tires on these bikes. I got 3000 miles on mine,not totally wore out. But wanted knobby tires,seems like a new bike.
Old 06-19-2023, 03:00 PM   #5
They don't even register In KMH. The reality is, they are just calibrated poorly for MPH readouts. The whole kilometers thing is a BS old wives tale that won't die.
Old 06-19-2023, 03:35 PM   #6
On my TBR7, the odometer is so far off, that it is closer to KPH, than MPH. The odd thing is the stock speed O is nearly correct, and GPS actually shows about 56, and 57 when the actual speed O reads 55. That's why, when I found a good deal on a very slightly used Zanella cluster, and speed sensor, I used it on my Hawk. It read faster than my actual GPS verified speed when sat to a 21" front, but now it reads pretty darn close after I sat it for a 19"
Old 06-20-2023, 09:51 AM   #7
I worked with a couple of guys a few years ago to figure out what the odometer/speedometer registered in, and the average number we came up with was between 1.3 and 1.4 (reading vs. Actual on the odometer), or 1 actual mile was showing as 1.3 to 1.4. So yeah, definitely closer to the Km side of things. Speedometer we're less off, but still pretty bad. About 6 or 7% optimistic.
I suspect it was a minimal effort conversion to "American" units.
Old 06-21-2023, 09:33 AM   #8
flopsweat   flopsweat is offline
flopsweat's Avatar
My stock tires on the TT250 were due for a change by 5k miles. The tires look pretty identical to mine, and they were noticeably squared off more like a car tire. Once I changed them, the leaning and low speed maneuvers dramatically improved, although it took awhile to get used to how it's supposed to feel again.
Old 06-25-2023, 04:18 PM   #9
CheapThrills   CheapThrills is offline
3rd year, several thousand miles on mine, but admit these knobby tires will soon be racing-slicks.
- My 2 Bikes:
TaoTao TBR7
Boom Vader Gen 2 (BD125-10)
Testing a YouTube Channel
Old 06-26-2023, 12:05 PM   #10
Magician16   Magician16 is offline
I've got something over 5,000 on the Storm tires. I changed out one on the Magician at about 3,000.
2018 Bashan Storm(sold)
2016 Magician 250
Old 06-26-2023, 06:45 PM   #11
This is a picture that I just took of the rear tire. The stock odometer shows 3650 . The bike handles just fine on the tire, but I don't figure it will be safe on a wet road http://
Old 06-27-2023, 09:50 AM   #12
Oldenslow   Oldenslow is offline
I'd be utterly shocked to get 3000 miles on those tires.
Old 06-27-2023, 11:56 AM   #13
flopsweat's Avatar
This looks identical to what mine looked like. I started to look up average mileage, is this normal, etc, until I finally took a step back and thought "that looks like crap, and I'm riding on nearly a 90deg angle of rubber at full lean". At that point I replaced them because I did not feel safe doing anything than a slow straight line.
Old 06-27-2023, 12:16 PM   #14
Just for comparison sake. About 4k miles on my Shinko 700's and I am fairly sure the rear will last about another 6 to. 8k miles, and the fronts will probably dry rot before ever being worn out.
Old 06-27-2023, 12:56 PM   #15
I have been looking at the Shinko tires on Amazon, and noticed that their sizes run different from the 110/90-17 . I think they just size like 5.10-17, which I assume is width, and rim size. Do you know what I should get to replace a rear 110/90-17, or what I should get?
