Old 03-13-2023, 03:57 PM   #1
lifankp250   lifankp250 is offline
Exclamation Broken Clutch Lever Assembly
I broke the clutch lever assembly and can't find the original part. Will installing an assembly from a different brand work as long as it has the same holder diameter of 22mm and connector pins?
The bike is a Lifan KP250 and i am planning to get the clutch assembly from a Benelli 180s since I can see the connector pins on it. But the question is is the system OEM locked?
180s, benelli, kp250, lifan
