12-01-2022, 08:59 PM | #1 |
Templar 250 (not X or M)
What do you guys know about the Templar 250 non X/M? Is it a new model or an old one? I see a lot of mentions of the Templar X and M but not the plain Templar.
I ordered one from Power Sports Max last week and I've searched all over but only found one guy on youtube with this bike. Surely someone on here has one. All I know is that it shares the same engine and trans with the M. It has shorter forks, a shorter rear shock, shorter wheelbase, smaller fuel tank, no skid plate and costs less. It's much taller than the Titan and no relation to the Hawk. |
12-01-2022, 10:00 PM | #2 | |
12-01-2022, 10:08 PM | #3 |
That's the one guy on youtube I found. Thanks anyway.
Edit: Actually I found 2 more guys with some youtube videos. Not much useful info. however. It finally shipped today so I'll know much more about it next week when it arrives.
22 Templar 250 Last edited by Fast_Freddy; 12-02-2022 at 01:25 AM. |
12-02-2022, 09:01 AM | #4 |
This is the original Templar that was sold early Summer when the Templar X showed up (5 speed version). The frame is slightly shorter, it doesn't have the adjustable suspension, and no rack. But it DOES have that awesome ZS172FMM-3A engine. It is the same engine I got on my 5 speed Templar X.
$1400 at PSM right now. Insanely great price for that bike. You will not be disappointed. |
12-02-2022, 01:47 PM | #5 | |
Oooo, I think you have a budding future YouTube carreer ahead of you. You could make a video with proper information in to help the rest of the folks out there sitting on the fence decide!
12-02-2022, 02:42 PM | #6 | |
22 Templar 250 |
12-02-2022, 02:43 PM | #7 |
Only if I don't have to dye my hair blue!
22 Templar 250 |
12-02-2022, 03:17 PM | #8 |
Please don't!
12-07-2022, 02:30 PM | #10 |
I hope he likes it. I'm waiting on my delivery ATM. It should be here any minute now. My biggest fear is shipping damage. Unfortunately my Dad is in the hospital so I may not get it put together for a while.
22 Templar 250 |
12-14-2022, 02:12 AM | #11 |
Well, I got my Templar and it looked as though R&L played fork lift hockey with it. one side was beat to hell and it must've been stood on end at some point since most of the motor oil was inside the plastic bag at the very rear of the bike. Surprisingly the damage to the bike was minimal. Broken rear turn signal, broken shifter, scratched fork tubes, a broken turn signal flasher unit and a broken headlight. I filed a claim with R&L but they haven't bothered to contact me. OTOH Power sports max has been easy to deal wiuth, They sent me a new turn signal and flasher unit but the shifter was out of stock so they offered a $31 credit which more than covers a new shifter. I just discovered the headlight issue.
My overall impression is good, both the Templar and PSM. Unfortunately it's been really cold here and my dad was in the hospital for a week. I've ridden it less than 2 miles so far. I'll update this thread later with photos and more info. Questions for Templar owners: 1) What size spanner wrench to adjust rear shock preload? 2) Any reason not to run 87 octane in this low compression engine? 3) What headlight bulb? 4) What diameter for the fork spring preload spacers?
22 Templar 250 |
12-14-2022, 04:38 AM | #12 | |
- I have not pulled the bulb, but might be different on the X. TexPete has posted details about the headlight bulb(s). -I have not taken apart front forks, so I don't know what size for shimming the springs But yes, you can run regular unleaded. I don't hear any detonation on stock ZS172 engines (5 or 6 speed). Note: Someone found the KKE suspension website. It is in another thread...Your forks and rear shock might be listed. KKE might respond to inquiries about them. BTW, R&L beat up my 1st Temp X crate. I don't know where the oil came from, but the crate was standing on end in the truck when it arrived at my house! A$$holes. |
12-14-2022, 10:53 AM | #13 |
I got the Motion Pro Shock Spanner Punch made for turning hard to reach lock and preload rings on rear shocks without damaging them.
People in the USA always think the Chinese print manuals for products sold worldwide only for them. Only the USA and Canada use the USA Octane rating system not the world. The 86.5 USA Octane is 90 Octane (RON). So the Chinese printed manuals for low compression engines have all this time been telling people to use USA 87. No one has replaced the LED bulb in the headlight that I know of, the problem is at the cheap levels there are uncountable resellers of Chinese products that claim sometimes absurdly high specifications, sometimes specifications that seem to even defy physics . But if you do replace it and don't know the good from the crap, I would probably pony up and get a bulb from a reputable well known industry brand thats been around decades as its not a frequently purchased consumable item and rather important in the dark. I have not pulled my forks apart.
12-16-2022, 12:55 AM | #14 | |
I was pretty sure that when the manufacturer stated 91 octane they meant RON not AKI but it doesn't hurt to ask. I filled the tank with 87 and it runs fine. If I have time I'll make some DIYs for various Templar essentials in the Spring. IMO the suspension is way too soft for a 250lb person so pvc spacers in the forks and a lot more preload on the shock are a must for me. I'll also rejet and unplug the idle air screw, change fork oil and possibly stiffer springs.
22 Templar 250 |
12-16-2022, 01:03 AM | #15 | |
I'll update again after I get to ride this bike more than up and down my dead end street. All I can really say about it now is that the suspension seems like it would work well for a 150lb novice rider. It's soft. The engine sounds great and has good power. Damn this cold weather.
22 Templar 250 |
