11-07-2022, 08:14 AM | #1 |
New from Ohio
Just purchased a Tao Tao Rhino 250. Really like the manual shift. We live in the middle of the woods and nothing is flat, so really need to do the gearing mod. With damp, leaf covered ground I expect to run chains year round.
I build and fly all sorts of RC craft even throughout the winter. Very excited to explore the possibilities of this machine. |
11-07-2022, 09:58 AM | #2 |
Welcome aboard!
11-07-2022, 02:16 PM | #4 |
Sprocket set
Thanks for the welcome. I have been looking around on the net. Would the 12x40 that you have be a better set than an 11x37. Just want to get a set and be done.Thanks
11-07-2022, 03:35 PM | #5 |
11/37 would probably be fine for most uses and better for chain wear. I use 12/40 because 40 tooth 428 steel sprockets are cheap.
11-12-2022, 10:30 AM | #6 | |
Sprocket replace
Thanksn |
