11-03-2022, 06:33 PM | #1 |
2005? Pantera 125
So, this old bike was sitting behind a neighbors barn under a tarp. I've cleaned it up, and I can fire it up, but as soon as it starts it throws oil out of a vent on top of the crank case, under the carb. I'm sure it's supposed to be a vent, but I'm not sure if it requires a valve? Like a PCV valve on a car? Or is it just meant to have a hose on it? The rubber hose that was on it was rotted off and isn't anywhere to be found.
11-03-2022, 10:16 PM | #3 |
...And run the (missing) crankcase breather hose down the back of the engine between the frame and the swingarm
11-05-2022, 09:13 AM | #4 | |
11-05-2022, 02:54 PM | #5 |
I remember your build thread. Somewhere here on Chinariders
Tags |
125, pantera |
