Old 07-03-2022, 08:06 PM   #1
gio2008rider   gio2008rider is offline
My 2008 Gio ATV just buzzes when I start it
So I have a 2008 Gio ATV which was running fine, but the back shock broke so I had to replace it. While the back shock was off I kinda let it drop a bit (I was still holding it tho), and the back dropped pretty low. After I replaced the shock I tried starting it and... nothing. So I topped up the battery with a smart charger, and now it just buzzes when I turn the key. Same battery, wired the same, but now it doesn't start. What can the problem be, everything is exactly the same except the shock.
Old 07-04-2022, 01:40 PM   #2
Jonny   Jonny is offline
Sounds like the battery can't produce the cold cranking amps to fire up the starter. I would grab some jumper cables and test it on your car's battery.
battery, gio, ignition, starter, starter motor
