06-07-2022, 06:52 AM | #1 |
Tao 110 Replaced Starter but still hardly turns over
I replaced the starter because it was barely turning the engine over. I had to hit the starter button several times ...click...click...click...then barely turns over.
I'm lost on this one...any suggestions?? |
06-07-2022, 06:53 AM | #2 |
after I replaced the starter it was the same click, click, click...then straining to barely turn over...
Leonard |
06-07-2022, 08:10 AM | #3 |
Sounds like you need a new battery
06-07-2022, 09:19 AM | #4 |
Check on the connections and clean them. Then check the battery.
2020 Lifan x-pect |
06-09-2022, 07:14 AM | #5 |
well, it's a new battery and I also put it on a 225A charger/starter resulting in no change...it just barely turns over after several tries...severe straining.
06-11-2022, 05:10 PM | #7 |
Try starting it with spark plug out. Also, try bypassing the starter relay by jumping it straight to the starter.
