05-03-2022, 03:37 PM | #1 |
Hawk 250 speed cable issues
What's going on everyone. Lately I had to reroute my speedo cable do to the cable getting wrapped around my horn, now my cable is damage and I would like to replace it what are my options, I have not purchased the digital cluster at this time not really sure if I will either. Thanks
05-03-2022, 11:51 PM | #2 | |
05-04-2022, 08:29 AM | #3 |
Ditch the stock cluster and go digital. It will be more accurate and the tach is nice to have.
05-15-2022, 12:10 PM | #4 |
My stock cable made it 2001 miles before the cable started to go and made the speedo bounce. Shame I had just confirmed it was only 2mph off at 60. Bought the Zanella, love the added tach and digital speed. Have the TBR7, set for a 17" wheel, only off by 1 mph.
05-22-2022, 09:58 AM | #5 | |
05-23-2022, 08:29 AM | #6 |
The zanella mounts exactly the same. It also uses the same connectors. There's an unused plug near the battery box that the dash uses for gear indication.
The only wiring I had to do was splice in the tach signal wire outside the connector. I did it last year and I think I soldered it, but you could use one of the snap together splice connectors. That went a little beyond the instructions, but it's better than stuffing the pin in the back of the connector and taping it like the instructions say. |
05-27-2022, 07:47 PM | #7 |
Had to change a couple of wires around because cluster is made for hawk not tbr7, just took the pins out of the connector and swapped them around. I cut and butt connected the old gear selector harness to the new gear selector harness to keep the stock connection at the steering neck. Tach wire I was able to attach at an empty connector pin at the steering neck. Fitment in place of old speedo is as if it were factory fitment.
