Old 03-26-2022, 06:07 PM   #1
Coggeshall   Coggeshall is offline
Thief busted my ignition!
Had my DLX stolen from the house a few weeks ago and just got it back after PD recovered it underneath a bridge.
Battery is shot, presumably from being abandoned on its side. The bigger concern is that they punched out the cylinder to hotwire it, busting the left bolting point for that cylinder. Looks like Orion PS sells replacements for $70.
Do y'all reckon it'd be secure enough with just 1 bolt holding it in? There's a slight chance I can tap it for a larger bolt. Also considering a fat blob of some sort of glue.
Normally I'd tinker my way to a solution, but a broken elbow makes taking it apart next to impossible. Great start to the riding season, huh
Old 05-04-2022, 03:48 PM   #2
Myinfo   Myinfo is offline
Maybe JB weld? It's not a stressed part, and you could drill and tap it later. Sorry about your luck, keep your head up.
Old 05-04-2022, 06:04 PM   #3
dig4dirt   dig4dirt is offline
Not exactly sure what is damaged but I agree that jb weld may do the trick.
Not sure if the spot would be able to be strapped or secured with the jb weld.
And good news (getting it back) to the horrible stuff people do as a human.
TBR7D
NGK...JT.Chain&17/42sprockets...ebayExhaust
Old 05-04-2022, 07:20 PM   #4
Nospark   Nospark is offline
Vote JB weld. make sure bonding surfaces are scuffed and solvent free. Tape off and wax any places you don't want to bond to and you can chip off those areas when cured. can be drilled and tapped if needed
2021 TBR7D
17 front, 42 rear
PZ30 Clone
Milwaukee, WI
dlx, ignition, key
