Old 03-21-2022, 03:40 PM   #1
weiser23   weiser23 is offline
Front break problems 2020 hawk
Got bike out from sitting over winter the front break is stuck there’s play in the break handle, we pulled the part out from master cylinder and it freed up the front wheel and tried to spray lube in it but as soon as you hit the break it’s stuck again,
Old 03-22-2022, 01:36 PM   #2
Ol,fart   Ol,fart is offline
Ol,fart's Avatar
Try removing the master cap then press the caliper piston all the way in. Then pump the leaver back up and see if it releases by itself.
2021 RPS Hawk "IKEA" (Came in a box with no instructions)
110 main jet 1washer,2.5 sprockets and the cat fell off( with a little help)
1984 Honda V65 Magna "Daddy's Little Monster"
To whoever stole my anti-depressants.
I Hope Your Happy !
Old 03-22-2022, 01:59 PM   #3
By "remove the part" from the master cylinder, I assume you mean the banjo bolt that secures the brake line to the master cylinder? It releases the caliper because you are releasing the pressure. Sounds like the master cylinder might need to be taken apart and cleaned/inspected. Try Ol.farts suggestion first and let us know how that goes.
Old 03-24-2022, 07:56 AM   #4
Thanks a lot I took the cover off and that did the trick front break is working great
