03-01-2022, 01:46 PM | #1 |
Brozz swingarm
Has anybody on here put one of these on either a TT 250, or an Xpect? They look soooo much healthier than what we have on our bikes. I looked at pics of the conversion, just not sure what all it requires. Any help is appreciated, thanks again folks!
03-01-2022, 02:16 PM | #2 |
Fits good on thr tbr7 but you'll want to get the brake mount and assembly too.
03-01-2022, 03:15 PM | #3 |
Thanks bro!
03-01-2022, 04:19 PM | #4 |
I mean your brake may line up with the supplied bracket which I think is for the Hawk caliper. I didn't like the single puck assembly that I got from the Brozz as it didn't have enough stopping power to slide around the rear tire and ended up buying a hawk 2 puck. Much better.
03-01-2022, 04:27 PM | #5 | |
03-01-2022, 04:33 PM | #6 |
Sometimes you can save money and time from the experiences of others here. Fortunately the parts are cheap so the learning curve isn't that expensive. Lol.
03-01-2022, 06:46 PM | #7 |
It fit my Hawk just fine. The only real catch is that you will need a shorter shock or the back end will get a lift. The Brozz.shock is the right size.to keep the ride height thensame. The brake bracket on the tt should work just fine. AFAIK, only the tbr7 needs that extra piece since their bracket is designed a bit different.
03-02-2022, 01:17 PM | #8 | |
03-02-2022, 06:25 PM | #9 |
In that case, if he can shorten it by 20 to 25mm you will be good to go
03-04-2022, 09:41 PM | #10 |
I'm wanting a Brozz swingarm for my Hawk. Finding one is the problem, though.
2010 Yamaha TTR 250 2020 RPS Hawk DLX 250 1989 Yamaha Big Bear 4x4 350 1984 Honda XR200R dual carb (Sold) You give me a reason to drink. I told her to stay right in the mud hole. She went left. Now her nickname is "Swamp Thing." Every hill is climbable, if you're brave enough. Let's go to the jewelry store, she said. It'll be fun, she said. |
03-05-2022, 08:40 AM | #11 |
Peace Sports told me a couple days ago they have some in stock. 55 bucks, plus shipping. They come in either black, or silver
03-19-2022, 01:01 PM | #12 |
I recently purchased one of these, and was wondering if anyone who has already installed it could let me know what the actual chain adjusting hardware looks like. I wasn't able to order everything as Peace was out of stock on some parts, so I'm missing the chain guard and all the actual hardware, meaning nuts and bolts.
Is the adjuster just a bolt of the appropriate size pushing back against the chain adjuster plates? If that is the case, has anyone used a chain adjuster "block" instead? I have seen these on some of my cousins japanese dirt bikes. https://www.amazon.com/Rippin-Moto-C.../dp/B09CR5SQRW |
