Old 11-26-2021, 09:07 PM   #1
757nick   757nick is offline
2021 TBR7 issues
So I have less than 1000 miles on my TBR7 and I have to issues I’m not sure how to deal with them.
So today I was riding and my bike kept staling out. It seems to only happen when the choke is off. The bike is warm every thing is fine then boom shuts off. I tried adjusting the carb but I have no knowledge on bikes and I’m learning.
Number two. My air box had the smallest amount of oil in it. I drained the oil and cleaned it all out the filter was try as hell so that’s good but I’m trying to see how I can eliminate the air box completely but all the videos Iv seen don’t really show you how they did it and I’m kinda nervous to fiddle with the bike and ruin something since I sold my car for this bike. Any tips for both of these would be appreciated thank you!!
Old 11-27-2021, 08:04 AM   #2
buzz   buzz is offline
hello sounds like carburetor is bad,runs with choke on not getting enough gas.And don't eliminate air box. check on here for that problem,hope this helps.
Old 11-27-2021, 08:16 AM   #3
just one more thing,did you check valves
Old 11-27-2021, 09:25 AM   #4
Yah I’m taking the carb off and cleaning the jets today. I assume oil is gunking it all up. I had oil dripping from the hose that feeds from the air box to the carb.
Old 11-27-2021, 09:52 AM   #5
good luck!
Old 11-27-2021, 01:49 PM   #6
I cleaned the carb it’s still having issues any other ideas to fix it? It’s idling so rough.
Old 11-27-2021, 01:53 PM   #7
Bruces   Bruces is offline
Post 3 above asked if you checked your valves .
Old 11-27-2021, 02:04 PM   #8
What valves??
Old 11-27-2021, 03:06 PM   #9
Intake and exhaust valves there are literally hundreds of posts about setting valves on these bikes and how to do it .
Old 11-27-2021, 03:08 PM   #10
I looked it up. So it should help the crazy idling issue? I noticed when I give it gas the rpms shoot way to high then boom drop. It’s insane how it could start having this issue over night
Old 11-27-2021, 03:11 PM   #11
Badluck   Badluck is offline
Originally Posted by 757nick View Post
What valves??
. You should do this anyway and at least check it every 500 miles at first, then after 2000 every other oil change.
Also check the intake boot the the carb attaches to and make sure it's not torn. I don't have a link to that part yet, but if it leaks that'll make it run lean and kinda matches your symptoms.
Old 11-27-2021, 03:23 PM   #12
Grin
Thank you!! I got the bike running nice. Cut out the air box and threw an air filter from my go cart straight on the carb and ran the hose from the air box with the pcv valve up the frame. I honestly think the air box is shit considering mine had cracks in the hose running to the carb.
Old 11-27-2021, 07:22 PM   #13
Good deal,
tbr7 250, tbr7 carburetor, tbr7 taotao reliability
