Old 09-23-2021, 01:13 PM   #1
46wl   46wl is offline
taotao carb
hello, I have a TAO 125 quad the carburetor is flooding and it seems to be a good time to change the carburetor. Any recommendations?
Old 09-23-2021, 02:17 PM   #2
PZ20.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I've had this carb flood also. I pulled the bowl off and cleaned the float needle. I also set the float height. Took care of the issue. I would try this first before installing a new carb
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 09-23-2021, 02:44 PM   #3
carb
hello, the carb bowl is riveted on thought it was not serviceable?
Old 09-23-2021, 03:36 PM   #4
Mudflap   Mudflap is offline
Are you sure those are rivets, most are screws with no slot. A Dremmil tool with a cutoff wheel can be used to make a slot.
Old 09-24-2021, 10:40 AM   #5
carb
I was looking at the carb with a dental mirror. I will have to take it off and check it out, I have a dremel. thanks
Old 09-24-2021, 02:40 PM   #6
epa carb
YES those are screws witht he heads broke off... you can slot the heads to remove with screw driver,,, alittle work and be CARFULL... or buy a carb.. if you hav e the time and alittle skill .. then go but some screws to install... use premium fuel. then ALMOST no trouble...
ABIBABA ATV ETC
Old 10-07-2021, 07:27 PM   #7
carb
hello, I was able to get the bowl off,cleaned it out, put it back on and it flooded at once. I took the bowl off again lowered the float . gas stayed in. I will have to see if the carb runs out of gas.
