07-16-2021, 03:19 PM | #1 |
2021 Taotao TBR7 Carb replacement
My 2021 TBR7 has a choke cable from the left handlebar to the carb - it allows for continuously variable choke adjustment. I would like to swap the factory (tamper proof) carb for one with conventional bowl screws.
I purchased a "cable choke" from amazon, but it does not have any provision for choke cable control (https://www.amazon.com/dp/B073SVJF2Q...roduct_details). Can anyone suggest an alternative carb that has provisions for a cable choke to be used? The carb I purchased is described as a PZ30... Thanks, . |
07-16-2021, 03:31 PM | #2 |
Those so called tamperproof screws can be removed. Just slot the screws with a hack saw or Dremel then replace the screws with new ones.
07-22-2021, 04:39 PM | #3 |
I took slide off bc bike is way to lean and On the Tao tbr7 it has one slide slot? I ordered the nibbie 30 mm carb hoping it works out
07-22-2021, 04:53 PM | #4 |
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.ebay.com/itm/324295819136 https://www.ebay.com/itm/111958216035 If at sea level, 110 main, 27.5 pilot, 1.5 turns out from fully seated on bottom fuel/air screw. I also have the same 2021 TBR7 and it runs correct with this setup. |
07-22-2021, 05:20 PM | #5 |
What is a pod filter?direct ignition coil? Oil cooler?
07-22-2021, 05:22 PM | #6 |
I steady bought the Nibbie 30 mm carb… hoping it works the box says Tao Apollo hawk 250
07-22-2021, 06:30 PM | #7 |
For the choke cable I found you have to transfer the old mount from the stock carb onto the new mount, or live without it.
Tags |
cable choke, pz30, tbr7 |
