05-27-2021, 06:55 PM | #1 |
Venom Ghost electric start does nothing
This may be something stupid infact it very likely is but I've been tinkering in the hot sun for two whole days straight so here goes
I have never started this bike because I wanted to get everything technical out of the gate and I had to source some non-ethanol gas as well. So I changed the sprocket which seemed relatively common place I'm almost positive everything is set up as it needs to as the wheel spins and the breaks work just fine but I digress I did some carb tuning threw in a 105 main jet and bored out the idle air mixture screw and put it 1 1/2 turns out and reconnected everything so I threw in some non-ethanol gas and the bike registers full battery/gas but when I take it off the kickstand and hit the electric start button it depresses slightly but there is no noise whatsoever the lights and everything else work still but its almost like the button isn't activating at all Thoughts? |
05-27-2021, 09:38 PM | #2 |
UPDATE: I crossed the solenoid which is what the electric start is supposed to be doing and the bike started right up but I quickly shut it down because I was worried because of me modifying it would cause some damage because despite reading and learning everything I still lack trust in my ability to properly tune a carb LOL
So once it did start (which was very quickly after I crossed the solenoid) I noticed what appeared to be smoke (it was very dark and the bike was only started for a few seconds) it may have been just natural exhaust fumes as I didn't think it through but the exhaust was covered by my bike cover because I genuinely did not expect the bike to start So tomorrow I will phone Venom and see whats up with my solenoid and I will again cross the solenoid and start the bike and record it so I can see if there is still smoke and then I will know what I'm working with |
05-27-2021, 10:03 PM | #3 |
So the solenoid is fine as that is what I'm using to start the bike but apparently it may be something else like the relay or even the switch in the handlebar so I will be back to investigating but glad to see its nothing stupid I may have done LOL
05-27-2021, 10:43 PM | #5 |
Yeah odd thing is that I could get it started by bypassing the relay and jumping the solenoid with a screwdriver without putting in the clutch and the kickstart was down so I don't think it has any safety killswitches so I'm thinking relay or something
05-28-2021, 07:32 AM | #6 |
Jumping the solenoid takes all of the safety switches out of the circuit .
05-28-2021, 07:46 AM | #7 |
Check that the wires are plugged in for the safety switch by the Clutch lever. Bike must be in neutral or have clutch pulled to start. Make sure the kill switch is in the run position.
