05-25-2021, 07:37 PM | #1 |
Easiest way to access Ghost carb?
Seems like at first look those auxiliary lights are in the way but I didn't investigate too far as I tackled other tasks. Whats the best way to get access to it?
Also any info on removing the seat would be helpful as I couldn't figure it out. Thanks! |
05-26-2021, 08:24 AM | #2 |
To remove those side covers you will have to remove two nuts from the back side of the cover that hold the lights on then you will have access to two bolts that hold the cover on. It was a pain but doable.
In order to remove the seat you will have to remove the bolts located under the rear fender. It took me a little while to figure it out. Check out my Saddle bag install video and it will show where they are located. Link to my YouTube channel below.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-26-2021 at 02:22 PM. |
