Old 05-06-2021, 11:55 AM   #1
TBR007   TBR007 is offline
Head Scratching Tbr7 help finding knobby tires & correct tube
So after riding my tbr7 on a 12 mile trail ride the other day I’ve come to the conclusion I need a more aggressive set of tires...not that I got stuck anywhere but they are Just more street oriented then I need them to be I’ve found a good rear tire size is 130/80-17 “motoz tractioner” I believe it was called that I’m gonna run from now on it’s still dot street legal but it’s far more aggressive so I don’t have to worry about the Rocky Mountain trails tearing up the street style tires and leaving me with a flat somewhere very inconvenient....I’m having some issues finding a front tire though the stock size is 90/90-19 anyone have any suggestions I can’t come across anything that’s a knobby style....also having a little issue picking tire tubes I believe they’re a tr6 style tube?!? Could be wrong so any help with picking up the correct tubes and a more aggressive front tire would be greatly appreciated
2020 tbr7
2008 R6
Old 05-06-2021, 12:52 PM   #2
I came to the same conclusion on tires on my first ride in a field across the street. The stock tires got stuck on about a 15 degree sandy incline. I've got a trail wing on back and d606 on front. I stayed with dot tires since I have to get it inspected, but next time I'll get some real knobbys for soft/medium terrain.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 05-06-2021, 01:06 PM   #3
Thumbs Up
I’m In that same boat I gotta keep it “legal” for inspection but these tires definitely cause me a whole bunch of unnecessary effort up mountain trails I just checked out the rear tire your running I found it in 4.60 x 17 which looks like the right size...pretty similar as far as the aggressive tread to the one I’m ordering for the rear....I really am having allot of trouble finding a front tire that’s a 19” knobby...looks like I’m gonna have to find a 21” front wheel like the hawks have to satisfy my knobby needs....as far as the rear tube do you remember what one did you go with...I believe I need a tr6 style valve stem 2.00-2.50 tube but I could be wrong....thanks for the help other then swapping to a digital cluster and changing my hand controls over to a aftermarket set with a lower profile master so my throttle cable has some room to roll far enough forward I’ve done just about all the mods/adjustments I want to make the bike suit my needs
2020 tbr7
2008 R6
Old 05-06-2021, 01:18 PM   #4
I think I bought a shinko sr241 or sr244 for my 19" front. It was super cheap and light and worked pretty good. It was pretty smooth on the street too.
Old 05-06-2021, 01:50 PM   #5
Thumbs Up
Definitely gonna check those front tires out thanks brother! now I just need to make sure I order the correct tubes for them lol...I seen on your signature you swapped your hand controls...what levers did you use? I couldn’t find any that would work with the tbr7 stock perches....genuinely thought the hawk style bike used the same levers...everyone said they didn’t fit so I ordered new perches and levers from mzs that used a slightly lower profile master cylinder....I searched around YouTube as well as the forum and couldn’t find anything about lever compatibility well I also can’t find what Inner tubes I’m supposed to be using either so that’s a little strange maybe I’m not using the search bar right or something since everyone says the stock tubes are super cheap/bad quality but I can’t find anyone who says they replaced them with this or that exact one!
2020 tbr7
2008 R6
Old 05-06-2021, 01:57 PM   #6
Skyd   Skyd is offline
Skyd's Avatar
I've HEARD that the thin poor quality tube issue has largely been addressed by the manufacturer, at least on the Hawk. I don't know that to be a fact. I've not swapped mine nor do I plan to right off.
I 2nd a look at the Shinko's I ran a set on my DRZ back in teh day and you can't beat them for the money. Not sure what all sizes they offer these days, but it's worth a look.
Also - we used to call those Trail wing tires - Death wings out in the woods and wet stuff. LOL
2020 RPS Hawk 250 - Build thread can be found here: http://www.chinariders.net/showthread.php?t=28374
"Do Wheelies and Forget your Feelies"
"If vegetarians eat vegetables, what do humanitarians eat?" -unknown
Old 05-06-2021, 02:19 PM   #7
Figured it wouldn’t be hard to find a post somewhere on the forums or YouTube with someone saying they have a tbr7 and used the x for the front & rear lol information is so plentiful for these machines I didn’t think this would be a hard one...for the front I’m going with a 100/90-19 kenda k760 as it’s dot street legal and aggressive then the rear I settled on a 130/80-17 motoz tractionator h/t since again it’s aggressive but street legal...guess I’m ordering tr6 style tubes since I think they’re the ones I need and if not using my stock tubes
2020 tbr7
2008 R6
Old 05-06-2021, 02:22 PM   #8
I've heard the same "death wing" thing , but 17" rears we dont get as many good dot choices, and the d606 rear was just too big and tall, it kept hitting my airbox.
Old 05-06-2021, 02:26 PM   #9
I used these: https://www.ebay.com/itm/7-8-Motorcy....m46890.l49286
Old 05-06-2021, 02:57 PM   #10
JerseyTBR7   JerseyTBR7 is offline
I came to the exact same conclusions in my research. I am also a TBR7 owner.
There is only 4.18 inches of room between the forks. The 100/90-19 is 3.94 inches. This is about as wide as I could find for this size for a true front tire.
I have yet to purchase but came down to these in my research:
Shinko E-804 Big Block Front Tire (100/90-19)
Kenda 692L5225 Motorcycle Tube - 350/400-19(100/90-19)
IRC Rim Strips - 19"/--
Motoz Tractionator Desert H/T 130/80x17 Tube Type for Honda XL600V 1989-1990
Bridgestone Motorcycle Tire Tube 120-130/80-17 TR4
IRC Rim Strips - 17"/--
Are you certain that the 100/90-19 Kenda k760 can be used as a front tire? That tread does not appear so.
Old 05-06-2021, 03:26 PM   #11
EA   EA is offline
I have the tractionator rear and it is awesome. Well worth it. And I have no issues going 70mph on the street either.
I'm actually running a michelin ac10 in the front because I couldn't find the tractionator in my size in stock anywhere. Don't be afraid to mix and match.
Old 05-06-2021, 05:29 PM   #12
Honestly no I’m not 100% sure about the kenda for a front tire...I just know size wise it will fit and has the knobby tread I’m looking for...also found a Michelin and a few others In the same size so I’m gonna look into it to see...for the rear I definitely have had good experience with the tractioner before so I was happy to find it in a size I can use
2020 tbr7
2008 R6
Old 05-06-2021, 05:43 PM   #13
idle_purr   idle_purr is offline
idle_purr's Avatar
Wheels Only:
https://shop.brozz250.com/eshopprod_...econ_Tires.htm
The complete set:
https://shop.brozz250.com/eshopprod_..._Wheel_Set.htm
NO HILL TOO STEEP NO MUD TOO DEEP
The Brozz | The Hawk Upgrades, Accessories, Etc...
Assembly Checklist: Brozz 250 | Hawk 250
~idle_purr
Old 05-06-2021, 05:45 PM   #14
Thumbs Up
Definitely appreciate the tune style as well! I genuinely thought I needed a tr6 good to know it’s the tr4! Also found a guy using the kenda as a front for his xr200 I believe it was said it tracks great so looks like I got my tire combo I was looking for put together...all in all 250 for both front & rear tires tubes and new rim strips isn’t bad in my opinion especially since I’m getting the traction in the mountain trails/rocks I’m looking for while remaining DOT street legal
2020 tbr7
2008 R6
Old 05-06-2021, 05:52 PM   #15
Originally Posted by idle_purr View Post
Appreciate the link, Though they appear to be a nice knobby tire...they’re not a brand I know of and not sure if they are officially DOT compliant
2020 tbr7
2008 R6
