03-17-2021, 08:17 PM | #1 |
What enduro and mods?
Looking at getting one of these 250cc enduro style bikes. Will be mostly off road use and just on road occasionally to get to trails.
Whats the best one to get? Theres the apollo 250 carb. The hawk 250 fuel injected. What other ones are there to look at? And then what are the best mods to get more power? I see a lot of people upgrade the carb on the Apollo. What carb works? And what sprockets should I run for more low end/wheelies? Thanks! |
03-17-2021, 08:30 PM | #2 | |
Banned
Pipe, pod, proper jetting. Proper valve clearance. Suspension mods will make a faster lap time than a 2hp gain would. They are already geared low. |
03-17-2021, 08:31 PM | #3 |
What brand do you recommend? What about the hawk 250 fuel injected one?
03-17-2021, 08:39 PM | #4 | |
Banned
The Hawk DLX would have been my next choice. It has a neat little closed loop efi that is reported to be excellent. Remember these are not for jumping. If.you want to jump it regularly you need to step up to a water.cooled 250 that is MX biased. |
03-17-2021, 08:42 PM | #5 | |
03-17-2021, 08:45 PM | #6 | |
Banned
For a wheelie happy rider (me too) be sure to change the fork oil to a good brand and weight, and consider some aftermarket fork springs. They arent very expensive. Will add finally that a 19" front is lighter and stronger for landing wheelies and such than a 21 is. |
03-17-2021, 09:07 PM | #7 |
Start with identifying what can or can't be registered q3here you live. If you live in a state that will register just about anything - aka, you can register a standard Hawk, then I would look at the rxb250l for a mostly off road bike. Better suspension and a bit lighter weight, new gen ohc 233cc engine making more power stock than a modded cg engine.
If not, then your options will be a bit more limited. The Brozz, Hawk DLX, Lifan Xpect, BMS CRP250, and TT250 are all 49 or 50 state legal bikes so registration isn't an issue.
03-17-2021, 09:16 PM | #8 | |
Banned
03-17-2021, 09:38 PM | #9 |
If your for sure primary use will be offroad, you need to look hard at the ORION RXB 230 and 250 L Models ,they have a stronger frame and better( and fully adjustable) suspension than any other China Bike i know of , leaving aside the GPX Models which are twice the price. They are in the $2k neighborhood as well, making them easily competitive with the Hawk DLX and Brozz 250's.
