03-02-2021, 09:01 PM | #1 |
Pre ride inspection check
Hey guys, does everyone check your bike over before you ride? I don’t always give my bike a full once over. Here’s a good reason for me to start!
Luckily the nail was bent and went in sideways.
2019 Z 400 2020 Tan Recon 2021 KLX 300 2022 GPX FSE 450R |
03-03-2021, 05:45 AM | #2 |
Well, I do check for stuff like chain slack, chain C-clip being still on, brake lines, cables, bearing seals and the such, as well as disk brake locks (don't ask me why... )
I occasionally do spot and remove a bit of gravel from between the tire treads (using street/cruiser tires on my '07 Zong....), but nothing that major Guess I'll check more often now... |
03-03-2021, 07:50 AM | #3 |
I always do a pre-ride inspection. I ignored a slightly lose chain once and ended up throwing the chain later in the day.
03-03-2021, 08:20 AM | #4 |
The chain is always loose on my Brozz! Perhaps an upgrade is in order for the next bike.
03-03-2021, 02:50 PM | #5 |
Yep, I always give my bike a once over for loose things, leaks, etc, and then check function of lights and controls. Since I tend to warm up my bikes, I do it then.
03-03-2021, 03:21 PM | #6 |
It should be unless you enjoy adjusting the chain after every ride.. my stocker was stretching constantly until i replaced it with the Niche X-Ring and now it stays put at whatever it was last tensioned at.
03-03-2021, 07:19 PM | #7 |
If I'm just riding around the neighborhood I just look it over. If I'm going more than a mile from the house I check tire pressure.
But the one thing I always check before I ride anywhere is that I have my phone... you just never know. Lol
03-03-2021, 07:31 PM | #8 |
It has always been drilled into me since I was a child to inspect any equipment that I use. Usually with bikes and ATV's I always inspect just because I've been stranded before haha.
NO HILL TOO STEEP NO MUD TOO DEEP The Brozz | The Hawk Upgrades, Accessories, Etc... Assembly Checklist: Brozz 250 | Hawk 250 ~idle_purr |
03-04-2021, 12:20 PM | #9 |
Check the swing arm axle bolt. I noticed that mine had some threads showing. I thought the nut was backing out. Nope! The hex head of the shaft had snapped off and the bolt was walking out on the nut side. I was lucky I noticed during a pre ride inspection.
