Old 02-21-2021, 01:38 PM   #1
BrozzBoyTn   BrozzBoyTn is offline
2018 Brozz 250 Rear Wheel Bearings
Hello everyone,
I have a 2018 Brozz 250. I was cleaning it up after some fun in the snow. While cleaning and oiling the chain I noticed some play in the rear wheel. I was wondering if anyone knew the size or part number for replacement bearings. This is the older model with rear drum brakes. Thanks for any information. P.S. I wouldn't mind numbers for the front bearing either. Will probably install new tires this spring and do bearings at same time. Thanks again.
