Old 01-05-2021, 06:52 PM   #1
Jgc731   Jgc731 is offline
integrated tail light for lil duc without cutting
anyone have a recommendation thats not the expensive TST one for an intergrated tail light / fender eliminator solution?
ive read some amazon reviews on certain "grom" intergrated tail lights and the clones usually have to cut the plastics for fitment issues. i tried some universal fender eliminator kits but the right turn signal doesn't clear the stock exhaust on the lil duc.
Old 08-04-2022, 11:07 AM   #2
Doubledown   Doubledown is offline
Interested in the same.
What fender eliminator is as close to bolt on as possible?
Does the little duc use a Grom taillight or its own version?
Old 08-04-2022, 03:09 PM   #3
4T_Goblin   4T_Goblin is offline
4T_Goblin's Avatar
Look at Kemimoto fender eliminator on Amazon
2020 Vader X-Pro X-7
2019 Kawasaki Ninja ex400
2022 Lifan KPX 250
Old 08-25-2022, 08:42 PM   #4
This is what I ended up with:
Tiddy Tail
Tail light
I didn't use to two side "fins" from the tidy tail/fender eliminator. They weren't needed and looked to be formed specifically for the grom tail.
Taillight fit in without cutting, just have to of course wire in your turns. The lil duc housing seems to be the same as the grom as I said this light fits right in. It was the factory lil duc tail that is has an oval shape on the bottom that stick out further than the grom light that got in the way of the fender eliminator.
I will say, I read reviews, and kid of agree that particular taillight has a dimmer running light that stock, but the brake light is super bright so I personally am not so worried about it. But again, you should be able to get any grom sized integrated light you want and it will fit if you like a different style.
https://drive.google.com/file/d/1fnw...ew?usp=sharing
https://drive.google.com/file/d/1d6t...ew?usp=sharing
