Old 11-11-2020, 06:30 PM   #1
daytonacat   daytonacat is offline
rear 2020 Boom Vader Sprocket
Folks;
I have probably over looked it some where in this forum, but what is the tooth count of the standard Vader Gen 2 grom clone rear sprocket?.
With a thrown out back I can not get down to do the counting myself.
Thanks in advance.
Carl
Old 11-11-2020, 06:58 PM   #2
I counted 34 on my son's Vader BD125-8, but might have missed one or two, or overcounted. Yours is the Gen 2, so possibly geared differently, but I couldn't see Baodiao bothering.
Old 11-12-2020, 11:08 AM   #3
thanks much guy.
Carl
Old 11-12-2020, 09:00 PM   #4
My 2018 Vader Gen 2 is also 34 tooth , i did not have to change the tooth count at all out back as i was able to do all the "tuning" i needed with just changing front sprockets, much less expensive and also less work , and Lord knows i am one lazy s.o.b. haha!
2001 Mustang GT
2004 Sportster
2018 VADER
2020 Orion RXB250L
Old 11-12-2020, 11:34 PM   #5
Ok, so I did count correctly. It's not difficult to count with the chain on, but it isn't easy, either, so I was hoping I didn't miss any, lol. What is the stock front?
Old 11-13-2020, 12:18 AM   #6
Big Bird   Big Bird is offline
Big Bird's Avatar
14t
2020 Boom Vader Gen 2
2019 CSC TT250
2021 Kayo Fox 70
Old 11-13-2020, 10:52 AM   #7
Originally Posted by Big Bird View Post
14t
Thanks! Is a 15t about as big as will fit on these bikes?
Old 11-13-2020, 12:11 PM   #8
deadwood83   deadwood83 is offline
deadwood83's Avatar
You can grind and make 17t work, but it;s ehhhhh. 16 fits without trouble. My old Hellcat came with 16 stock on the front.
Old 11-13-2020, 12:56 PM   #9
Big Bird's Avatar
16t is what I run. Seems to be the best all around performance wise. Mine tops out at about ~8500rpm @ 60-62mph gps on flat ground with no headwind. 17t is probably better for cruising at high speed but at a loss of hill climbing power and acceleration.
I did need to cut about an inch from the lower part of the sprocket cover to get rid of chain rubbing with the 16t.
2019 CSC TT250
2021 Kayo Fox 70
