11-03-2020, 07:00 AM | #1 |
Parts links needed
Rear sprocket is flopping around a lot so I’m wanting to replace the 4 sprocket bolts. As far as I can tell the hammer head side of them has wollered out letting them wiggle around back and forth. Thank god for the C clip! I was down to 2 nuts when I could hear the chain trying to jump ship.
This is all for the 2017 Storm bike, if there’s any links to other consumable parts that may need replacement along with those hammer head bolts it would be appreciated.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
11-05-2020, 09:44 AM | #2 |
Bumpity bump bump
11-05-2020, 10:38 AM | #3 |
Studs (Part number 90128-ke2-940) for the Honda XL185s will work and so will the Stud bushings
(Part number 41241-307-010) . https://www.ebay.com/sch/i.html?_fro...2-940&_sacat=0 https://www.ebay.com/sch/i.html?_fro...7-010&_sacat=0
11-05-2020, 12:31 PM | #4 |
I would have chimed in earlier but I didn't know if they were the same as the Hawk 250. this is where I picked up the sprocket studs within a reasonable amount of time and money.
https://www.hondapartshouse.com/oemp...106/rear-wheel
~ toys in the cave (in the order of addition) 81 Honda XL185s {work in progress} 2018 QIYI Coolster 3150CXC 150cc Quad 2019 QIYI Coolster 125cc Quad 2021 Roughhouse 50 (neat little scooter for the wife) 2022 QIYI Coolster 3150DX-4 I may not be fast but I am "Half-Fast" |
11-06-2020, 04:47 PM | #5 | |
Thank you sir! You the man.
11-06-2020, 04:48 PM | #6 | |
11-14-2020, 01:34 PM | #7 |
Had to order the expensive bushings but a friend made me the bolts
11-14-2020, 03:44 PM | #8 |
I found these to use on my XL185 project.
https://www.ebay.com.au/itm/4pcs-Gol...5/183289306220 They did fit however I did have to use some washers as spacers to take out some rear sprocket side slop, which might not help with the OP problem described. They were the cheapest full replacement set I could find and I was trying to keep costs down so it's probably a case of you get what you pay for. The C Clip that actually holds the sprocket on the other hand is something I would not cheap out and go OEM for. |
11-16-2020, 02:28 PM | #9 | |
Those look like the OEM that came on the bike. For the C clip I’m trying to source the OEM although I believe any name brand (Honda) clip the same size would be made of better materials.
11-16-2020, 02:29 PM | #10 |
Can any of y’all see the photos I shared? I haven’t been able to since starting the thread. Just curious.
11-16-2020, 03:31 PM | #11 |
I can't see any photos. I have to resize mine to the smallest file size to get them to upload.
