Old 10-24-2020, 04:28 PM   #1
djdanielalan   djdanielalan is offline
djdanielalan's Avatar
Oh No BD125-8 Shuts Down between 5-6k rpm
This thing is driving me nuts. Idles and revs and holds fine in neutral, but once in gear and hit 5000 rpm looses all power. Will even shut off. I've had to ride home at 3000 rpm. Replaced CDI and coil. Checked timing which appeared to be a tooth off. Even swapped carbs. Anyone experience this or have an idea?
Old 10-26-2020, 08:08 PM   #2
Nobody has had this experience? It's driving me crazy! There's not too many parts left I could replace on the bike to troubleshoot and it's still running like shit. I'm so tired of working on the bike, I just want to get it running properly so I can sell it and buy a Honda. This thing is junk.
Old 10-26-2020, 08:25 PM   #3
Bruces   Bruces is offline
any Chance your cdi has a rev limiter in it ? If it’s a generic one from an atv or a smaller kids bike that might be how it was set up
Old 10-26-2020, 08:32 PM   #4
it does not. It started doing this even with the old cdi, which i now assume is still good. Doing wheelies with the crew and it started cuttting out in wheelies and on both wheels as well.
Old 10-28-2020, 02:04 PM   #5
Kronik Racing in Simi Valley is close by you and Pete, the owner is pretty much the guru when it comes to Baodiao. However, before calling, have you adjusted the valve lash?
https://www.kronikracing.com/
Old 10-28-2020, 06:21 PM   #6
Thank you! I couldn't find my feeler guage, so I overnighted some from Amazon. They actually just got here now lol.
Old 10-29-2020, 10:38 AM   #7
I know that people have, in the past, suggested using aluminum cans as a feeler gauge (I forget what its thickness is), but that was for vertical singles as found in the dual-sports, and I think the gap was fairly close depending on bike's engine brand (usually Zongshen 2xx cc vertical thumpers). Not to mention, it seems that every single brand has their own intake and exhaust gap specs, so I guess using cans would be more for stuck on the side of the road valve lash adjustment, lol. BTW, what are the specs for these engines?
Old 10-29-2020, 05:18 PM   #8
oincman   oincman is offline
Is any of the emissions stuff disconnected? If not, check all your vacuum lines and tank vent. If it is disconnected, try hooking back up. Try removing the fuel filter and running straight to the carb. Just my .02
Old 11-10-2020, 12:57 AM   #9
.003" intake and .005" exhaust (when using performance parts)
According to TBoltUSA https://tboltusa.com/store/tech.php?...%2C+and+Timing
Old 11-10-2020, 01:05 AM   #10
Emissions crap was removed the day I got the bike. I do have an inline fuel filter, but there is free flowing fuel coming from the line. I've been out of town and just getting back to work on this thing.
I'm convinced there's something electrical going on here. I noticed my led light kit reboot when I pressed the starter button the other night. CDI, coil and V/R have all been replaced. I have a new battery arriving tomorrow. Process of elimination lol.
Old 11-10-2020, 08:29 AM   #11
Just throwing this out there but seen it before on here. Are you using a resister spark plug with a resister coil wire cap? That will cause a weak spark.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
