10-07-2020, 08:09 PM | #1 |
Coil problem.
Does anyone know what the correct ohms readings should be on the coil on a 2stroke Chinese mini pocket bike. I get a reading of 1.5 ohms when I set my multimeter at 20k on the ohms setting. I can't get a spark on this bike. I bought a new coil but still no spark and am getting the same reading on the new coil. I am thinking that the new coil is faulty as well. Any help appreciated.
10-08-2020, 06:06 AM | #2 |
Not sure of what the Ohms should spec out to, but is the area that the coil is grounded clean, rust and paint free?
10-08-2020, 08:04 PM | #3 |
Yes it is, thanks.
10-09-2020, 02:38 AM | #4 |
It's more likely a problem with the CDI or stator. While you hear about different ohm coils with cars, it doesn't generally seem to be something that varies much with motorcycles.
10-09-2020, 07:43 AM | #5 |
He has a 2 stroke rope start pit bike Franque ,with the lawnmower style coil ,no stator ,no cdi ,just a magnet on the flywheel .The problems could be the magnet ,the coil itself ,the spark plug,the plug wire ,the plug connector ,or the kill circuit .There is nothing else involved .
