45 to 55 should be no problem, but I personally would change out the front and rear sprockets to more street-friendly gearing not for top speed, but to greatly reduce the vibrations these bikes can put out. I would suggest a 17 tooth countersprocket and mid-40s or lower rear sprocket. If you still want gearing for light trail off-road or dirt road you could probably get away with a 46 tooth rear.
60 mph is no problem with the right sprockets. I've rode mine for literally hours . I've taken mine on 75 to 130 miles rides. The 17/45 or in my case 15/40 which is about the same gear ratio is a good combination for on and off road. The reason i choose the 40 rear was if i planned on mostly highway i would put a 17 tooth on front and could easily cruise 60 -70 mph. Just make sure you tune the carb so it's not running too lean. These bikes come way too lean from the factory.
#6 | |
The sprocket change is recommended for comfort at highway or biway speeds. At your planned commuting speeds, the bike will be good to go with a sprocket change. Oh, and these bikes need about 300 miles or so to break-in. Many a member have posted within the first few miles how slow their Hawk seems to be. Once they hit at least 300 miles, they report how the engine is like night and day. So, keep that in the back of your mind.
Here in Denver at 5000 ft, my hawk runs perfectly. The crazy thing is, when I take it up to 10k-11k for trail riding, it does great there too! The internet had me very worried about the stock carb for no reason!
#8 | |
It seems that US Resellers are actually doing some QC (which they should have done always) on the motorcycles they are shipping. If go back to 2014 and keep reading post till 2020, you will see that the newer the hawk is, the better jetted seems to be. |
I can confirm that the Hawk can do extended highway speeds from 60-70 mph with a 17/40 gearing. I ride mine on the highway every day and it performs just fine. If you want to do the occasional highway jaunt and keep it trail rideable without losing too much low end torque, go with 17/45 or 17/43 if you’re a lighter bodyweight fellah.
