08-19-2020, 04:02 PM | #1 |
Stiff shift lever on Apollo db-36 2019
After a long ride when I come back home and try to switch it into neutral from first the shift lever is very hard to click up. I have a an Apollo DB-36 2019 & I'm a newbie. Also, for some reason after I ride a bit and make a complete stop with the clutch held in the bikes tends to wanna die. What seem to be my problems any advice is welcome. Thanks in advance.
08-19-2020, 04:40 PM | #2 |
The clutch is dragging once it get hot. You need to adjust the free play in the clutch lever. You want minimal free play, about 1/8" .
08-19-2020, 06:11 PM | #3 |
So you're saying by adjusting my clutch lever on my handlebar by a minimum of 1/8th of an inch will correct the stiff gear selector & the turn off when i come to a complete stop from riding?
08-19-2020, 06:56 PM | #4 |
You need more freeplay. Just Google how to adjust a motorcycle cable clutch.
08-19-2020, 08:03 PM | #5 |
I adjusted the free play just now. Went riding and now at complete stops, after riding for a bit, the bike creeps forward with the clutch lever pulled in all the way.
08-19-2020, 08:18 PM | #6 |
Adjust it a little more
08-20-2020, 12:23 PM | #7 |
I adjusted it more but now feel like its hard to upshift & downshift & cuts off at complete stop. This is very frustrating.
08-20-2020, 12:52 PM | #8 |
Sounds like you giving it more free play. Even though this is for a TT250. The adjustment procedure is the same. https://www.cscmotorcycles.com/check...and-adjustment
08-25-2020, 07:44 PM | #9 |
I got it adjusted to my liking but every so often I gotta adjust it on the handle bar lever
08-25-2020, 08:03 PM | #10 |
Are you a new rider ?
08-26-2020, 06:46 AM | #11 |
Yes I am.
