Old 08-13-2020, 03:51 PM   #1
Gooseberry   Gooseberry is offline
CG125 Engine conversion to 250 Help
Hi
So I have been looking at buying a 230cc - 250cc engine that will bolt into my CG125T frame as a fun project. I was originally looking at an overbore kit but looking at research its a one way ticket to a melted engine.
Looking at multiple sources I found a couple of brands to look that being Loncin, Shineray and Zongshen. They all appear to have 250cc engines that follow the same design as the CG125 engine but I am uncertain if the dimensions line up. I'm aiming to have as simple time as possible changing over the engine so no mounting brackets/aligning the chain sprockets.
Basically what I'm trying to find is just an engine that will bolt directly in, hopefully has a bit of power behind it (well whatever a 250 can deliver) but also reliable, price isn't too much of an issue.
Any help is welcome.
Old 08-13-2020, 04:08 PM   #2
franque   franque is offline
As long as it isn't counterbalanced, any of the 'normal' 250s (that is to say not a true 250), even the OHC models, should bolt right in. You might need to make a different top mount, but that should be really easy.
Old 08-13-2020, 04:16 PM   #3
Why do I not want it to be counterbalanced? I do actually have a spare Honda CB250 nighthawk engine that might be able to fit in.
Old 08-14-2020, 06:41 AM   #4
I'm only taking about Chinese made motors. I have no clue about Nighthawk fitment (personally, I hate those motors, too much vibration and too little power for it to be worth it, also not worth the extra weight, to me). You don't want a counterbalanced motor because it protrudes more in the front, meaning it might either hit the lower downtube, or require you to fab up a new front mount. From what you were saying, I assumed you're looking for the easiest bolt-in possible, so I was giving you the option with the least amount of fabrication.
Old 08-14-2020, 04:12 PM   #5
Mister104   Mister104 is offline
A cg250 will fit into a cg125 without issue. Assuming the lower crankcase profile is the same it should bolt up using the same front engine bracket.
Old 08-14-2020, 04:23 PM   #6
FYI I have a cg300 engine, in a CG125 frame.
cg125, cg250
