Old 06-28-2020, 01:12 AM   #1
RYU583   RYU583 is offline
RYU583's Avatar
Need help getting parts for RED CAT
Hello everyone,
I just purchased a RED CAT dirt bike which I believe is 150cc. The Shift shaft has been sheared off and needs a bit of work.
Anyone know anything about this bike or what bike is compatible as far as parts go?
It looks similar to the RPS Viper, but I am not certain they are identical.
Where would be a good place to get parts for this bike?
Thank you all and be safe
Old 06-28-2020, 07:10 PM   #2
I would probably start with the RPS bike. Not too many 150cc dirtbikes for reference other than the RPS as far as vertical engines go. The rest seem to all be pitbikes.
Edit: Baja Motorsports had a Hensim 150 dirtbike (which would also be the same as the RPS) and Baja still has a site, although they don't sell bikes, but do have parts catalogs. Not sure if they are even in business, but it couldn't hurt to call!
http://www.bajamotorsports.com/parts_catalogs
Old 06-28-2020, 08:55 PM   #3
humanbeing's Avatar
The 5-speed CG125 seems as stock (19.5cm). The longer 1 is found in trike or 175/200...
Forget the 4-speed in left as u won't find that config in offical imports...
Typical CG125:
Old 06-30-2020, 10:19 PM   #4
RYU583's Avatar
Thanks!
I tried contacting a vendor of the RPS Viper and they wrote back telling me that even though the bikes look identical.....the parts are not compatible
not sure how accurate that is
Old 06-30-2020, 10:23 PM   #5
RYU583's Avatar
Typical CG125:
Thank you.
so will the CG125 shaft work for my 150?
