06-08-2020, 09:29 PM | #1 |
I want more air.
Look to try a good cone filter, what's the best for my Storm? I may try modding my filter box to take a K&N. any suggestions?
06-09-2020, 01:35 AM | #2 | |
You also have the option of doing a DIY foam panel filter by modding your existing paper filter. Simply cut out the paper bit, buy a Uni foam filter panel, glue in place around the edges. A couple of members have done that on here and were decently satisfied with the results. That would be my route if I were wanting to keep the air box at least.
06-09-2020, 07:45 AM | #3 |
I agree with Dan. A good foam filter flows better than the Paper and even the K&N.
06-09-2020, 10:03 AM | #4 |
I have a uni on my storm. Happy with it but the boot did rip. its been on and off a ton for carb tinkering so i can't fully say it was due to quality issues. The angled one tucks in really nice, ill take a pic at lunch.
06-09-2020, 12:02 PM | #5 |
Any Uni-type foam filter with a slight neck bend with a 42mm inlet will work.
https://www.amazon.com/s?k=42mm+moto...ref=nb_sb_noss
06-09-2020, 04:22 PM | #6 |
Thanks everyone, A Uni it is! I'll buy one as soon as someone throws up a link ...Thanks 2LZ , I might try the foam in the air box but for now I'll just throw one on and see.
06-09-2020, 04:25 PM | #7 |
I use an outerwears to help keep the water and dust out
06-09-2020, 04:30 PM | #8 |
06-09-2020, 04:35 PM | #9 |
is it 42 mm or 44 mm ? I see both linked.
06-09-2020, 04:48 PM | #10 |
44 I believe. Fits fine, just don't over tighten the clamp, think that's how I ripped my boot.
06-09-2020, 05:02 PM | #11 |
Thanks Duck9191, I bought the one you linked. I'll look at that cover your sporting next!
06-09-2020, 05:12 PM | #12 |
That's the one I am running. Bought it direct because it was cheaper. Have one on my sxs too. Easier to brush it off and keep going VS washing, drying and oiling the foam all the time. Oh yeah, get a recharge kit too lol.
I used this one, k&n kit will work too. https://www.amazon.com/dp/B00FFZU0P0..._fR.3EbQH60N85 Outerwears
06-09-2020, 06:51 PM | #13 |
These are the style I run. Link is to unavailable, but you ca see the style. Usually run for 8 to 10 bucks each. https://www.amazon.com/Amyli-Angled-.../dp/B07QPX17RZ
You can find them on ebay as well. I have 2. One on the bike and themother cleaned, dried, and oiled in a bag ready to swap out. Uni filter oil is what I use. I oil the inner and leave the outer dey, but if you might encounter water hou can also oil the kuter foam to help semi water proof it.
06-13-2020, 08:31 PM | #14 |
Well I got it on. But surprisingly I'm thinking I need to downsize my jet. Now it runs better with half choke ( w/ no back fire)and bogs with the choke off and dead at the top of the throttle. I thought I'd need more gas?
06-13-2020, 11:14 PM | #15 | |
I literally have two filters that require a very large difference in jet size. My dual foam filter with a 152-155 main, and my K&N style which so far has needed a 140, which is still a tad rich.
