04-07-2008, 08:10 PM | #1 |
Guest
Posts: n/a
vibration is back
but i dont care. I reckon its another engine bolt that needs tightened. i just changed the oil and the screen was totally clear and the oil was not metallified or anything. bike runs great but numbing my hands.
gonna keep on keeping on...i got 1800+km and its FUN!!!! |
04-07-2008, 08:20 PM | #2 |
Anyone tried to balance the flywheel? Doubt the factories devote much time to balancin them.
No drill holes, no balanced :(
Wayne Wildfire WF300-SP |
04-07-2008, 08:22 PM | #3 |
Guest
Posts: n/a
I think the discumbobulator is going out on this thing. Either that, or the thingamajiggy is working its way loose. But it still runs good.
04-07-2008, 08:29 PM | #4 |
It's symptomatic of a bent johnson rod because the thingamajiggy on the china bikes is just for looks and doesnt function like the ones copied from the jap bikes.
Get rid of the stock engine bolts and get some real bolts in there and you'll never have to mess with them again. (If you'd have seen how I ride my bike after doing the bolts you'd have done yours already) You now know for sure what the REAL problem is and the fix is GOOD quality bolts. |
04-07-2008, 08:42 PM | #5 | |
04-07-2008, 08:48 PM | #6 |
If you read elsewhere by usmc_mustang, he actually found the cause of my bike's transmission problem--the mechanic from south of the border!!
04-07-2008, 08:51 PM | #7 | |
If you actually split one of these cases, it would scare you. You would no longer worry about things like balancing. Heck, the clutch basket alone scares me enough to keep it at 55.. Just an FYI, the lower crank gear on the OHV motor, is only a press fit on the crankshaft. No roll pin, no bolt, no woodruff key. Not sure on the OHC, didnt pay attention when I had the last one apart.. |
04-08-2008, 11:54 AM | #8 |
Guest
Posts: n/a
TC could the grommits on the hoojamawhijjet be faulty?
