Old 01-22-2020, 01:01 PM   #1
Savageman69   Savageman69 is offline
Trim repair ideas please
Broke two of the plastic clips on the gas tank trim. The clips that slide on to the metal tabs on the tank. Picture included below.
https://photos.app.goo.gl/98gcPS8iF6Xfv3T66
Old 01-22-2020, 01:28 PM   #2
I've broken one of the tabs off on my Hawk because I forgot to unbolt the cross bar the first time I removed the tank. I used JB plastic weld and has held up for three years. I also repair plastics on my daughter UTV and still holding up after a year. Good stuff. Just make sure you clean the plastic with alcohol or degreaser and rough up the surface you are repairing.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 01-22-2020, 01:30 PM   #3
diyRdie   diyRdie is offline
diyRdie's Avatar
Bend a piece of wire like this
Use soldering iron to melt the "tabs" on the ends into the plastic then cover your melty / weldy work with jbweld. Had the same problem on my magician when I had a stock tank. I used this to completely replace the plastic loop things. Hope this helps.
----------------------------edit----------------
Wire thing not to scale, the shape for your loop thing may be different. Or you could try plastic welding with a soldering iron it's hard to tell what would work best from the photo as I'm not familiar with that exact bike.
Good judgment comes from experience, and often experience comes from bad judgment.
MY BIKE'S THREAD
Old 01-23-2020, 11:48 AM   #4
You can also buy a cheap plastic soldering iron at HF, along with a pack of filler rods. IIRC, the package includes ABS, PP and PVC. Google how to do a burn test to determine the type of plastic you have and use the appropriate filler material.
Alternatively, you can trim off a sliver of plastic from an area that doesn't show and use that as filler material.
Old 01-23-2020, 09:08 PM   #5
NzBrakelathes's Avatar
Megadan should have those panels and more that I left with him, contact him maybe if a near complete set interests you etc
Or plastic weld or epoxy etc might work too
Old 01-24-2020, 03:25 AM   #6
Damn thats a good easy idea! I'm gonna give it a shot. Thanks for all the advice guys.
