Old 12-29-2019, 12:24 AM   #1
Dht1998   Dht1998 is offline
New Vader 125! How to bend exhaust pipe?
Just got my Vader 125 from powersportsmax and so far im loving it First mods i did were change the engine bolts out, and change the brake and clutch levers. I have a 17t sprocket, a mikuni carb and a ransoto grom exhaust all going on soon. I already took the stock exhaust off and i knew the grom exhaust wasn't gonna fit without modification, it looks like i have to bend the pipe a bit where the existing bend is, the question is how did you guys bend the pipe? I would take it to a muffler shop but they are all closed Sundays, if i could do it myself that would be great if not ill wait to take it somewhere to get it bent.
Here's some pics of the new ride!
File Type: jpg 59926846387__2470DEFB-344A-4486-B360-CE39F1FFE092.jpg (88.3 KB, 507 views)
File Type: jpg 59926844495__FA0AD3F1-87F7-4D7F-8340-75AAEE389D50.jpg (93.7 KB, 488 views)
Old 12-29-2019, 09:50 AM   #2
wheelbender6's Avatar
I have not done it before, but you could heat it with a propane torch. Bend it around a 4 inch wooden log to prevent a crease on the inside of the bend. Good luck.
Old 12-30-2019, 02:26 PM   #3
ikeus685   ikeus685 is offline
Send a message via Yahoo to ikeus685
Good luck! You see the blue color on the pipe.. What you will need to do is where the bend (s) are to be.. You will get a bulge on the inside of the pipe unless the bend is just a minor tweek. PipeFitting and bending curves are a black art best,, if left alone.
Yes look up pipe shaping by heat or exhaust bending on y tube
Old 01-04-2020, 10:05 PM   #4
Whisky   Whisky is offline
Whisky's Avatar
I had to bend a grom exhaust and I must say buy exhaust that already fits, its a big pain to bend and makes the pipe look like crap.
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 04-14-2020, 08:44 AM   #5
maldoj2   maldoj2 is offline
see my bike
Old 04-14-2020, 08:49 PM   #6
Ninjaguy23   Ninjaguy23 is offline
Ninjaguy23's Avatar
I got the same bike from Powersportsmax. Had to go through the whole bike. It was missing the swing arm nut. Lots of loose bolts that needed loctite & had to re-route pinched hoses & rats nest behind the headlight fairing. I’m looking to do the same mods to get some more pep out of the lil engine. Don’t try to bend that pipe yourself you will screw it up. Especially if it is stainless “not malleable without massive heat”. I saw a vid on you tube, guy tried everything to bend it with no luck. Ended up taking it to a muffler shop twice to get the right angle. Said it was a royal pain in the arse!!
Good luck let us know how it works out.
Cheers!!
