Old 12-16-2019, 10:01 PM   #1
a_hi   a_hi is offline
Ideal RPM range for RX3?
Hey all,
First day riding my RX3 and I was running it pretty consistently between 4-5,000 RPMs. Is this along the same lines as others? This seems very high compared to Japanese bikes, but I guess these have a higher red line tolerance. Please let me know your experiences, don't want to be pushing it too hard. Also noticed I really had to speed up to get into 6th gear (around 75-80kph). Does anyone have experience consistently riding in 6th gear, and did the bike seem to struggle?
Thanks!
Old 12-17-2019, 12:21 AM   #2
NzBrakelathes's Avatar
I’m around 7-12000rom
100kmph genuine is near 8000rpm as speedo is 15% off
These are a short stroke motor huh and need to rev
Old 12-17-2019, 06:34 AM   #3
Ok good to know!
Old 12-17-2019, 07:03 AM   #4
franque   franque is offline
The majority of 250s running through town will be turning those kinds of rpm. Anything on the highway, well, there's a reason that most small bikes don't have tachos, and I don't think it's just cost. I think you're probably lugging it if you're in 6th at those speeds, these motors need to be revved, same as a Honda 250 trying to go the same speeds.
Old 12-17-2019, 02:40 PM   #5
This bike runs like most any other 250, they need RPM to make power. I run mine to red line on every single ride and cruise in town around 5k, and higher on the highway.
2016 RX3
2002 Honda CBR1100XX
Old 12-17-2019, 05:17 PM   #6
Working_ZS   Working_ZS is offline
Power Band Sits At 6-8000 RPM
I'll echo what the others have said, you need to rev the engine for highway speeds (55-65 mph). You'll be running 6-8000 rpms most of the time, depending on what front and rear sprockets you have fitted (14T front & 44T rear are OEM on CSC RX3's). Don't worry about the engine, it's designed for it and is happy to rev this high all day long, without complaint; mine is approaching 16,000 miles without any problems.
Old 12-18-2019, 11:32 AM   #7
Gaijin   Gaijin is offline
I have done hours and hours and hours at 10,000 RPM. The only way to get highway speeds out of an RX3 is to dial up the RPMs. Longest day I did was 675 miles, and I would estimate that 95% of that was at wide open throttle and about 75 mph.
