12-15-2019, 03:36 PM | #1 |
Blue Brozz
I turned my Brozz from Red to Blue over the past couple of weeks. I really like the blue color. When I ordered my Brozz from Peace I accidentally ordered red - I have no idea how I did that but it was definitely my fault. Jeff gave me a great deal on some blue plastics and I just finished putting them on. I also installed brush guards. In addition to the plastics change, I basically took the bike apart except removing the engine. Changed fork oil, front and rear brake fluids, greased steering stem bearings (and had to add some loose bearings as there were some missing), greased all the rear linkages, inspected the wheel bearings, changed the tires, cleaned up the wiring, and a few other odds and ends. Came out pretty good I think. Just need winter to end lol
2019 Bashan Brozz 250 2019 Honda Africa Twin CRF1000L |
12-15-2019, 04:24 PM | #2 |
Looks good.
12-16-2019, 12:03 PM | #3 |
That blue is really sharp. Do you have a basement entry?
12-16-2019, 01:04 PM | #4 |
I do. Just a set of stairs coming down through a door. Works pretty good getting the bikes down. Going back up is a little more difficult but not too bad.
