Old 10-06-2019, 11:15 AM   #1
herbie   herbie is offline
LED Headlight Bulb
I recently added some LED driving lights and I like the brightness they have and would like to update my headlight bulb as well. If anyone has replaced theirs with a LED and would recommend it I would greatly like to hear about it. Thanks
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 10-06-2019, 11:32 AM   #2
OneLeggedRider's Avatar
The BeamTech H4 LED rawks! I have one and I gave the other to Justin and he loves it as well, and he had a SuperBright LED before and still prefers the BeamTech.
https://www.amazon.com/BEAMTECH-Head...Y04Q3FS3YHHMDS
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 10-06-2019, 11:43 AM   #3
Baskt_Case   Baskt_Case is offline
Baskt_Case's Avatar
I second the BeamTech!
You WILL see and BE SEEN!
2018 Hawk - Nibbi PE30, Nibbi Intake, UNI Filter, Ebay Exhaust, NGK 4929 (non-Iridium), 428 D.I.D. X-Ring, 15/40 Sprockets, Walmart AGM Battery, IMS Shifter, Full LED Lighting, Digital Cluster, CSC Swingarm Pin, Modified Chain Adjusters, Upgraded Wheel Bearings
** MPH Cruise, ** MPG
Old 10-06-2019, 11:48 AM   #4
Also the BeamTech seems a little expensive at $40, but you get 2 bulbs. And it uses a heat sink which is outside of the headlight housing so you don't have to worry about a noisy cooling fan failing.
Old 10-06-2019, 11:54 AM   #5
Baskt_Case's Avatar
OneLeg, off main topic but how did you like the LED turns and tail? Mine are stupid bright at night, I love em'. My front turns are actually bright enough during the day that I can see them blinking out the top of the lens and thus reminded to turn them off, albeit 2 miles after the left turn!
Old 10-06-2019, 12:22 PM   #6
You'd have to ask Jay, he's been the only one riding it. But yes, they are extremely bright and he mentioned the same about seeing them flash in the daylight and them reminding him to turn off the signal lol. Almost wish it had that loud and annoying beeper on it like the TBR7 comes with.
Old 10-06-2019, 05:31 PM   #7
Thank You for this! I will be checking it out
1978 Kawasaki KL250
Old 01-02-2020, 09:55 PM   #8
Goob   Goob is offline
Hello,
I got an LED headlight bulb from Ebay that works great. Only $18. My priority was plug and play. I didn't want to have to mess with modifying anything.
This has fewer Lumens than those with the big heat-sinks (that require mods), but still 2x my stock halogen. This is the partial URL (actual is way too long), but if you put the description in an Ebay search it should show up.
http://www.ebay.com/itm/AUXITO-H4-90...ulb-Hi-Lo-Beam
As an aside, I also replaced the taillight 1157 bulb with an LED that strobes (then goes solid) when you brake. Here is the URL:
https://www.ebay.com/itm/2x-1157-750...gAAOSwJeVdlNZK
Peace on Ya!
Goob
