Old 10-02-2019, 05:17 PM   #1
Ac21   Ac21 is offline
Front tire position
On the hawk I noticed the front tire is a little closer to on side then other in relation to the forks. Will moving one fork correct this? I mean if I loosen the bolts from the fork tree and slide one of the forks up or down until there's equal distance?
Old 10-02-2019, 05:51 PM   #2
AresROC   AresROC is offline
AresROC's Avatar
Interesting... any picture?
At first I thought mine was because rim is offset from the hub due to loose spokes. My buddy turned the steering wheel against the steering stop, gave the front wheel a good kick, and it aligns perfectly again. That is what we did on the trail. I will loosen clamps and then re-tighten them. Upside down forks with thicker tubes would be less prone to this...
Edit: Loosening the fork clamps had no effect. I tried to lift one fork higher, and after a few bounces it came right back. The source must be fork twist and caused by triple clamp's top steering stem nut... project to come...
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D
JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair .
Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2
BSR Chronicles - "Project leads to more projects!"
Yamaha WR250R
Suzuki GSX-R 600
Old 10-02-2019, 08:06 PM   #3
OneLeggedRider's Avatar
On mine and several others I've noticed the top of the tire sits closer to the left fork. I think this is caused by poor casting and there's really nothing you can do about it.
Edit: What I'm referring to is the front axle mounts on the forks not being machined properly/horizontally, not the tire being tweaked left or right. And I think the OP is referring to this as well.
~ Don't poke the bear ~
M.M.I. Dean's List graduate class of '95 and Specialty welder
2020 Ice Bear Terifecta 150cc Trike
2011 Honda Foreman 500ES 4x4
2001 Polaris Scrambler 400
Old 10-03-2019, 12:45 PM   #4
Not the best picture
Old 10-03-2019, 03:33 PM   #5
Yep, mine does the same.
