09-10-2019, 10:11 PM | #1 |
Hawk 250 issues riding
Hey guys I’m new to the Chinese bike world. I bought a new 250 two days ago. It was supposed to be completely tuned and ready to ride. When I test drove it it seemed sluggish. I figured it was not quite warmed up. Today I cranked it up. It was idling low. I cranked the screw a bit and got it where it sounded good. I take off on it ride for mabe a minute never got past third gear. Turned around to come up a hill down shifted and died. Ok no big deal. So I try to crank back up and it won’t crank. Let it sit for a few minutes and crank it back up. Take off riding does the exact same thing. Messed with it for a couple hours adjust idle screw every which way. Can’t keep it running. After it dies and I get it cranked back up I shift into first and dies until I leave it for a few minutes. Anyone know what my issue could be? I can’t even get the bike broke in at this rate. Any and all advice is greatly appreciated.
09-10-2019, 10:19 PM | #2 |
Valves need adjusting. Valve come set too tight from the factory. Read the Hawk resource guide sticky at the top of the Dual sport section.
09-10-2019, 10:24 PM | #3 |
Couple things I would check if it were my bike.
First, I don't believe it's tuned an ready to ride. Time to rejet, shim the needle, etc.. Second, adjust your clutch lever/freeplay. Sounds like when it's warm, the clutch isn't disengaging all the way so when you drop it into gear, it stalls the bike. |
09-10-2019, 10:34 PM | #5 |
If the carb still has the tamper proof screws on the bowl it wasn't tuned. The stock carb come tuned very lean from the factory. Also you need to get some miles on it before it loosens up. It will run much better after about 500 miles or so.
09-10-2019, 10:34 PM | #6 |
If you purchase the ready to ride bike packages you should have just lit your cash on fire instead. At least you’ll get some street credit.
What everyone else said valves, adjust them and post back. Your good.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
09-10-2019, 10:48 PM | #7 |
Ok good deal I was being hopeful and read many forums. I figured I was going to have to get into carb and adjust valves. Most issues I found with everyone else were idling So I was kind of getting worried because mine is idling fine. Glad adjusting the clutch was mentioned, because I never thought about that. I got the assembly fee waived. So I didn’t really waste any money. I got the bike assembled and TTL for 1300 out the door. I will be running though all the suggestions. It might be a few day before I get back with results due to crazy work schedule. I really appreciate everyone.
09-10-2019, 11:01 PM | #8 |
where do you have the choke lever?
09-10-2019, 11:09 PM | #9 |
The choke is open
09-11-2019, 12:11 AM | #10 |
Myne was doing similar stuff coil another thing to consider, I adjusted valves before had problem, cutting out dieing , then just no run, no spark at plug my consideration was recitifer or coil tried cheapest first easiest to work on coil fixed problem, the dual sport maintenance an setup helps
09-11-2019, 02:45 AM | #11 |
Here’s a couple things well suited to most first tune china bikes:
https://rover.ebay.com/rover/0/0/0?m...2F303210680840 http://rover.ebay.com/rover/1/711-53...g&toolid=11111 |
09-11-2019, 06:42 AM | #12 |
Welcome aboard and congrats on you purchase. Good luck on your setup and keep us posted. All the comments are excellent! Pix are a plus!
A family that works together, plays together, shoots and trains together, and sleds together, stays together. Second amendment! SkiDoo sleds, NOW 2 TTR225, and a BMS250. A couple of quotes (we are not farmers) "I don't get off the farm much" "Am too old school" I call the china bikes "the china syndrome". |
09-11-2019, 07:24 AM | #13 |
Once you get that stuff sorted out it will ride great. Guy sold me his with less than 40 miles because he could not get it going right. I did the work stated above and I have about 4,500 miles on my hawk. Also I am not really the mechanical type but was able to complete all this work myself.
Congrats on the purchase and i am sure you will get it figured out and purring like a kitten. |
09-11-2019, 12:11 PM | #14 |
Is the mixture screw accessible at the bottom of the carb. I just glanced last night and didn’t notice one but I have read there is one under a tamper proof plug
09-11-2019, 01:03 PM | #15 |
On my Hawk carb it had a plastic plug. I used a drywall screw and screwed it right into it and pulled it out.
