Old 09-03-2019, 10:09 PM   #1
Musictrek   Musictrek is offline
Musictrek's Avatar
200 miles on the 2019 Brozz
Ran the Brozz 28 miles in 108 degree heat here in the southwest Brozz ran well! I went to a 20w50 oil. The shifts to neutral have been easy!
Old 09-04-2019, 01:49 AM   #2
Azhule   Azhule is offline
Those temps will easily fry a brain and the human body, stay well hydrated on those fun hot day trips (still beats sitting around in a hot cage using A/C)
Old 09-04-2019, 10:48 AM   #3
My commute to work was 33 miles a day in Yuma, year round. Since it was early, even on the hottest days, the 16.5 mile run to work was not bad temperature-wise. The ride home was a bit of a beast, however. It wasn't so bad through the county roads, but once in the city limits, sitting at stoplights for 20 minutes (ok, a bit exaggerated, but it FELT like 20 minutes) made me want to fall over and die/melt. What is your ride like? I understand it is nearly double my old commute.
