08-28-2019, 09:56 AM | #1 |
New Bashan Storm 250
Hello all! I just picked up a 2018 Bashan Storm 250. I got it from a dealer local to me in Mesa, AZ. Paid a little more than normal ($1799) but it was already setup and ready to go, 1 year registration, and I have a 6 month warranty.
08-28-2019, 11:14 AM | #2 |
Nice bike! Thanks for the pic.
08-28-2019, 11:17 AM | #3 |
Now that you got the picture posting figured out we will be waiting on more as you do the mods.
08-28-2019, 11:38 AM | #5 |
Good to see another storm. Any plans for mods?
Im in the process of adding an exhaust, adjusting the valves, adding a 12v power point on the handle bars and figuring out why my front rotor warped.
08-28-2019, 01:10 PM | #7 |
I would recommend a digital dash, stock one sucks, a lot lol. There are a few of us with them and we have some post on mods. I made one for the cluster swap, ill probably make one for the exhaust too. Tako AKA nzbrakelathes is working on a digital cluster combo too, his will be a kit. He has a pz30b kit too if you want a pumper carb.
thats the thread for the cluster install. http://www.chinariders.net/showthread.php?t=24110
08-28-2019, 01:30 PM | #8 |
Tako has a carb tuning, valve adjusting and Pumper carb kits. Personally there's no need to buy a new carb. The stock carb is tunable.
https://www.ebay.com/sch/nzbrakelath...p2047675.l2562
08-28-2019, 03:12 PM | #9 |
duck9191 and JerryHawk250, thank you very much for the info!!! This is going to make things a lot easier and the digital dash sounds like an awesome upgrade, I may have to do that one first!!
08-28-2019, 08:55 PM | #10 | |
Wheel speed sensor I have a sample the location gap isn’t perfectly where it should be but that’s not important to be fair as it’s just a spacer etc or buy the blue eagle or TT250 wheel sensor if you’re really picky but not a must. I’d need the info from main plug to repin etc 2 bolt gear indicator switch at motor? |
08-28-2019, 09:11 PM | #11 |
Single bolt gear sensor Tako, that one you had me try was perfect. The speed sensor will work with the index tab anywhere but if you can get them a bit longer then the one I tried that would be helpful. I still haven't found my pinout from the stock cluster, I know I have it somewhere and I'll send it to you.
