08-01-2019, 10:00 AM | #1 |
Front Fork Guard Apollo 250 DB36
So i tried to spray paint my front fork guard but messed up royally and for the life of me cannot find one that matches the apollo 250 db36. Anyone have any inclination to an exact OEM or another model that will work?
08-01-2019, 10:14 AM | #2 |
08-01-2019, 10:35 AM | #3 |
yea i saw that one but I dont want to pay 50 bucks for fork guards. that seems a bit excesive
08-01-2019, 11:01 AM | #4 |
Can you post close up pictures? May be similar to the Brozz or Storm.
08-01-2019, 11:09 AM | #5 |
yup will do tonight
08-01-2019, 11:16 AM | #6 |
08-01-2019, 11:19 AM | #7 |
I messed up painting my plastics many times, sand it off and try again. The right pant is key. I use krylon fusion and to avoid the dreaded crinkles I make sure to let the paint cure 24 hours between coats. You have to make sure the plastic is clean before you paint it so I wash mine with dish soap. At this stage my plastics look better then factory. What was the problem with your paint job?
08-01-2019, 02:44 PM | #8 |
i probably didn't sand well enough nor did i clean well enough. I used this spray but it was super runny and didnt stick
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
