07-24-2019, 12:22 PM | #1 |
key fob does not work. reprogram?
how do you reprogram the key fob on a tao atv?
07-24-2019, 04:08 PM | #2 |
Have you checked the battery? I had one that would work when it felt like it. Turned out the battery came loose from the hot glue that held it in place. Re-glued it in place and was good to go.
07-28-2019, 01:15 PM | #3 |
battery for fob
I see the battery is a 12 volt battery on these.... yes I would like to know how to re-program them as well... I guess check youtube for this..
07-29-2019, 04:45 AM | #4 | |
More or less the same as https://fccid.io/Q6W986/User-Manual/users-manual-360911 Find something machine translate it https://drive.google.com/file/d/1GJd...ew?usp=sharing https://zhidao.baidu.com/question/100777121.html
