05-25-2019, 07:01 AM | #1 |
Plastics
Does anybody know if the body parts/plastics from the bros 160 or the XR150l
fit on the hawk 250? |
05-25-2019, 08:53 AM | #2 |
Different
I have some plastics new red or black What you looking for? |
05-25-2019, 03:49 PM | #3 |
Don't need i was just asking because they look similar and i might need some in the future
Thanks |
05-28-2019, 02:55 PM | #5 |
I done that the first time I removed the tank. Forgot to remove the bolt from the bracket. JB Plastic weld works great. It's been over 2 and a half years and still holding up.
05-28-2019, 04:21 PM | #6 |
If it is ABS plastic you could use a dab of acetone which will melt the plastic and fuse it together once it dries. Be careful though, you don't want to get the acetone on any plastic part that you don't want marred up. You might test it on the back of one of your panels first to see if it will soften the outer layer of plastic, if it does work it will fuse better than any other plastic bonding solution out there.
05-28-2019, 09:44 PM | #7 |
its Polypropelene plastic. I've mended mine extremely well with a soldering iron and melting it together...
05-29-2019, 11:21 AM | #8 |
Harbor Freight carries a cheap plastic welder (basically a soldering iron with a flat tip) and rods for PP, ABS and PVC.
06-14-2019, 03:10 PM | #9 |
Well shit, I think I lost the little broken piece. Maybe I can make a bracket.
06-14-2019, 03:43 PM | #10 |
Try Versimold. its moldable silicone. Youtube how it works. you'll end the new plastic idea.
https://www.amazon.com/Versimold-VM0.../dp/B00NQ11AQI
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
06-17-2019, 11:48 AM | #11 |
i broke that tab off almost right away.
3m 2way tape that to the gas tank,, make use its the grey removeable stuff not the white foam stuff.. works well and comes off when you need it to.
500cc Hawk Project http://www.chinariders.net/showthrea...372#post281372 |
