05-06-2019, 04:12 PM | #1 |
no fire
Can't get fire to plug. Replaced so many things that I am confused myself and getting ready to set it on fire after I throw it thru the dealers window
05-06-2019, 04:47 PM | #2 | |
What all have you checked and/or replaced so far..... Have you checked the stator??? Have you replaced the CDI??? Have you checked the coil???
2006 Roketa DB-07-200 Dual Sport 2007 Monte Carlo SS 5.3 2010 Challenger Hemi 5.7 2004 Isuzu Rodeo 1998 Kia Sportage 4x4 2004 Toyota Tundra 2016 Ford Escape Guitars 1970 Gibson SG mint Condition 2005 Epiphone white Custom SG Les Paul L/New Fender Banjo New Condition BC Rich Bitch - Like New\ 3 Jay Turser SG Good Condition Amps Marshall vs100 Good Condition Acoustic 261 very good condition Boss GT-6 Pedal effects Like New |
05-06-2019, 05:10 PM | #3 | |
You can also try removing the black and white wire from the CDI connector which is the kill wire to rule out that one of the safety switches is not faulty.
05-06-2019, 08:43 PM | #4 |
no fire
Have replaced CDI and coil. Will get rid of b/w, don't even need a kill switch right now, lol. Had it running the way it was by a home made ignition switch and jumping solenoid with needle nose. Would love to get that again, it's my only transportation right now.
05-06-2019, 09:02 PM | #5 |
no fire
Sorry. It is a Bashan 250 Bruzz. 3200 miles and will be a year old in a couple weeks. Called the factory in Ga. this morning and talked with someone. He was informative but not a mechanic. He told me some good prices on parts and I will buy from him next time but I am out of money and luck for now. The # is 770-662-1898. The guy I talked to was Jeff. I think the parts dept. guy was Dave. This is the Peace Sport factory in Ga., not sure what all they make there but they make my 250 enduro and ship crate bikes to dealers. The engine is fine (built in the factory). All the troubles that I have had were from the dealer's (Scooters Plus, Summer ave., Memphis, Tn) sloppy work putting it together. If I knew what I know now, I would have put it together myself
05-06-2019, 09:21 PM | #6 |
I do not know how to check the stator and do not have kick stand safety. I finally found a generic wiring diagram by typing in "bashan 250 wiring". It was accurate and wire colors were matching. I have wiring for burglar alarm that was not on the diagram and is complicating matters. At this point I am trying to dedicate wiring for starting/running. I will get rid of b/w wire to CDI and see what happens. I am really wondering why I have no fire to coil.
05-07-2019, 12:39 AM | #7 | |
05-07-2019, 03:57 AM | #8 |
Occasionally there have been reports of wires being pinched where they come out of the left side engine casings....ARH [/QUOTE]
Yes, I was going to tell him this too... right inside the casing is a 6 pin plug I believe that plugs in to work the safety switch.. ( Neutral ) if is not making good contact your bike will not get spark to the plug... play with those wires and see if she starts up some...
