04-30-2019, 10:28 PM | #1 |
1 full year
1 full year today since I paid for the CB. Figured I would give it a present. Cleaned the carb up, new filter and oil, new tail/brake socket/bulb. It *idles slightly better at 1100rpm with the clean up. New filter lowered the volume at the tail pipe considerably.
*A thing I noticed is I’m about plum out of idle adjustment space on the screw, 1 more 1/3 turn and it’s fully tight. I have kept the mix screw at 2 full turns out from tight. I feel like I have to bump the idle back up via the idle screw about every other month. So by August I will be out of room if the procedure keeps going as is. Hmmm.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
05-01-2019, 05:43 AM | #2 |
hey Chip... Have you tried a PZ30 carb on it??? may give you more adjustment room... I use the PZ 30 and have a lot of room on mine... runs really good... I don't mess with my adjustments daily.. just set it and go...
2006 Roketa DB-07-200 Dual Sport 2007 Monte Carlo SS 5.3 2010 Challenger Hemi 5.7 2004 Isuzu Rodeo 1998 Kia Sportage 4x4 2004 Toyota Tundra 2016 Ford Escape Guitars 1970 Gibson SG mint Condition 2005 Epiphone white Custom SG Les Paul L/New Fender Banjo New Condition BC Rich Bitch - Like New\ 3 Jay Turser SG Good Condition Amps Marshall vs100 Good Condition Acoustic 261 very good condition Boss GT-6 Pedal effects Like New |
05-01-2019, 09:06 AM | #4 |
If you cleaned out the pilot jet and idle mixture circuit and still have turn out the mixture screw more that 2 turns then you will need a larger pilot jet.
05-01-2019, 09:10 AM | #5 |
It came with the PZ30. That got changed to the Mikuni with 117.5/25 jetting.
05-01-2019, 09:16 AM | #6 | |
I was getting massive sounding back fires when letting off the throttle at 50mph is what inspired me to crack the carb open and tinker. It ran great this morning but had to start it 4 times in a row.
05-01-2019, 09:18 AM | #7 | |
05-01-2019, 02:31 PM | #8 |
I had a 27.5 pilot on my last Hawk because a 25 was on the lean side with full bolt ons. I ran a 115 main during the hotter months, and a 117.5 when it was cooler (around 50deg. range). I agree with Jerry, up the pilot size.
05-01-2019, 07:11 PM | #9 |
Ok thanks again guys. I’ll give the 27 a whirl with 1.5 turns in the fuel mix screw.
