04-20-2019, 10:01 PM | #1 |
BD125-15 BOOM VADER NO FUEL Question!!
Good evening & greetings from damp Central Connecicut Fellow China Riders!!!
To get to the point--My problem is I am not getting any fuel to my carb and on further inspection no fuel is in the fuel filter either!! What could cause this? I have a Gen 1 Boom Vader built 09/2018. As always replies are much appreciated!! Thanks everyone whos reading this!!!
"Hope for the best, Prepare for the worst, Be pleasantly surprised when the world doesn't fall down on you" "Life's too short not to enjoy it-So's my China Bike!"-Me Last edited by sirmaxwell; 04-20-2019 at 10:37 PM. |
04-20-2019, 10:31 PM | #3 | |
I do have a pinch in a large line that goes to my airbox at one end and I have no idea where at the other end
"Hope for the best, Prepare for the worst, Be pleasantly surprised when the world doesn't fall down on you" "Life's too short not to enjoy it-So's my China Bike!"-Me |
04-20-2019, 11:49 PM | #5 |
yes I have tried the fuel shut off switch/petcock in the position that was working ever since I got the bike and then tried both and even inbetween positions but nothing worked. It is possible the petcock is broken inside and stuck shut==Although the fuel filter is above the petcock towards the fuel tank and the fuel filter is bone dry too--so I dont know I mean I guess if there is a blockage anywhere in the fuel system from the tank to the carb bowl it COULD cause fuel to not flow from the tank at all but IM NOT SURE if the fuel would flow from the tank to wherever the blockage is or would the blockage keep the fuel stuck all the way in the tank and not let any fuel into any of the lones no matter how far away from the tank the blockage is
04-21-2019, 01:34 AM | #6 |
Check tank vent hose
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
04-21-2019, 02:29 AM | #7 |
I have no idea where that is, kinda hard to find things without taking fairings off. I did take off the gas cap to try and release any possible "vapor lock", not sure if that would fix any possible vent hose mishaps, but i will definitley look for that vent hose thanks.
I've also been wondering what the heck this thing is in the attached picture. It looks like a nipple where a hose would attach coming off the air box but it is just capped off with a sealed bit of plastic and hose clamp. It seems like maybe I should take off the plastic and attach a hose to it..? But I am totally clueless about what it is as of now. As always any help is greatly appreciated!!!
04-21-2019, 07:35 AM | #8 |
I also noticed this morning that I have a line about the size of a fuel line just sticking out to open air towards the top of the triple tree--if Im on the bike its in front of me just poking our and I never noticed that one before. Maybe thats my tank vent? I had the bike outside and was going to start pulling it apart when it started raining.again. I saw the fuel filter filled halfway with gas today when I opened the gas petcock shutoff and at first I was happy because I could hear gas flowing but then it stopped...SO I took off the gas line from where it goes into the petcock/carb and I was expecting the fuel from the filter that I could clearly see to fall out but it didnt--SO it must have some kind of vacuum shut off as well that only allows gas from the tank when the intake is sucking in air. AS a stupid experiment I tried blowing into the gas line towards the filter which fouled the vacuum hold on the fuel and caused a few ounces or however mych to splash out, some on my face the first time!! :( but it would only let out a quick little bit of gas perhaps replacing the volume of air I was blowing in I dunno. SO I am guessing I have some kind of fuel vaccum pump thing or whatever you call it that has gone bad--BIG surprise as those and emissions systems are notorious for having leaks and failing on these bikes. Anyone know how I can fix this based on my description? And Anyone know or have links to a video on how to eliminate the vacuum fuel induction? Thanks as always any answers and help is much appreciated!
04-21-2019, 07:57 AM | #9 |
the cock at the carb is turned on but I am now suspecting this bike has a vacuum cock as well--I see an air line about the diameter of a gas line going to the air intake boot that is between the carb and engine and I bet the other end of that line would have to go to either a vacuum cock that sits between the tank and the carb or it would have to go to the carb itself...but i am guessing it must be a vacuum cock that I have no idea where it is--yet--that I will have to find that is probably faulty. The vacuum cocks are a good idea because it makes it so you only get gas when bike is running and they can even add a little fuel pressure but they are faulty as heck at least the stock ones on china bikes are notoriously bad even when new and I have always had to take them off of scooters.
04-21-2019, 08:09 AM | #10 |
Gas should come out whether bike is running or not its gravity fed. If you took the gas cap off and gas didn't flow into the filter then its not the tank vent, somewhere the gas line has to be crimped. Are you sure there's gas in the tank?
04-21-2019, 09:41 AM | #11 |
I suspect what you will find is a crimped / pinched gas line ,thats real common with these bikes, stuff poorly routed . As a sidenote to that , the stock black "rubber" fuel lines in particlar quickly start to degrade due to US gas having a lot of ethanol in it, which is BAD for chinese fuel lines. it's possible the fuel line has already started to "flake" on the inside and is making a partially crimped fuel line condition worse, you need to get some 3/16" silicone fuel line from AutoZone or any parts store and replace that stock fuel line asap .
04-21-2019, 01:39 PM | #12 | |
yes there is definitley a half tank or slightly more in it. If there is one of those vacuum petcocks found on scooters and some other bikes then the gas wouldnt flow without the engine turning over. Similarly if the line is crimped it would cause the same effect of not letting the gas thats right there go any further. I have no idea if there is a vacuum petcock or not for sure although I am kind of thinking maybe there is one since there is an air line going to the intake boot coming off the engine--this line would wither go to the carb or a vacuum petcock or i guess possibly even it could go to a vacuum emissions system also . i will check where that line goes hopefully in the next few hrs I will definitley check for a crimped line. Unfortunately it is soo hard to see under the fairings that I feel like I might need to take them off if I cant get it figured out easily--I really hope it is just a crimped line that I can remedy without taking the fairing off but we shall see. Also as a note if I take the gas line connection off the carb and blow into the line towards the fuel filter then some gas will come out--probably equal to or similar to the volume of air I put into it--but then the gas stops flowing again. Not sure if that means anything? or not sure even why I tried that since it got gas on me! lol
04-21-2019, 01:42 PM | #13 | |
04-21-2019, 02:07 PM | #14 |
Shell v power is ethanol free in my area
04-21-2019, 03:23 PM | #15 |
I would take the plastic off and start where the line comes out from the tank, it's got to be something simple since there isn't much there to look at, the line into a shut off valve then to filter then into carb. That's it.
