03-31-2019, 10:02 PM | #1 |
Unknown Pilot jet
Can anyone recognize this jet? I pulled image from online but it's the same one on my Lifan KP mini. It came from a Sheng wey carb. Standard Main jets fit but can't find these pilot jets anywhere online.
04-01-2019, 08:20 AM | #2 |
Ahhh! The mystery jet. Good luck finding those. Same pilot jet that comes on the stock Hawk carb. What size did it come with? If it is a 40 you should be okay as far as the pilot jet. Try adjusting the idle mixture screw. It will be hidden under a plastic or brass cap.
04-01-2019, 10:12 PM | #3 | |
04-04-2019, 01:35 AM | #4 |
You can find a #45 on Clevland cyclewerk site,
https://clevelandspeedshop.com/colle...c-full-jet-kit or simply drill it out I have searched in China and I can get 1000 made sure but not going to bother as drilling the jet out is good enough. I have this is my bike a 223cc OHC - I drilled it out to 0.45mm and correctly adj air screw - problem solved. Here's my listing should it help you https://www.ebay.com/itm/303077495104 |
05-12-2019, 09:54 AM | #5 |
Actually I managed to find these
