Old 02-14-2019, 12:18 PM   #1
Pathfinders   Pathfinders is offline
This is why you do pre ride inspections
I had the day off and it is going to be 60 here today. Was going thru a pre ride inspection and noticed a loose nut on the swingarm bolt. I tightened the nut a few turns and the bolt started turning. Look at the other end of the bolt and the head had sheared off. The nut was not loose the bolt was working its way out.
Any idea on the bolt size? I would like to get a grade 8 or hardened bolt to replace it. I do not know how much of the bolt went with the head.
Roy
Old 02-14-2019, 01:37 PM   #2
It's a 14mm diameter bolt. Not sure of the exact length. I think it's around 275mm long. Just measure the overall width of the swing arm assembly.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 02-14-2019, 03:23 PM   #3
Thanks Jerry.
Old 02-14-2019, 04:13 PM   #4
wheel spinner   wheel spinner is offline
Man you are lucky that you did the per-inspection and caught it... that really could have turned out to be a very bad situation for you... All I got to say is you have an angel in your corner...
And far as the bolt, make sure you take the nut with you so you can make sure it screws on... it really wouldn't hurt to buy a new nut... if the head of the bolt was sheared off flush with the swing arm.. chances are you can compare the bolts together for size less of the head on the new one...
2006 Roketa DB-07-200 Dual Sport
2007 Monte Carlo SS 5.3
2010 Challenger Hemi 5.7
2004 Isuzu Rodeo
1998 Kia Sportage 4x4
2004 Toyota Tundra
2016 Ford Escape
Guitars
1970 Gibson SG mint Condition
2005 Epiphone white Custom SG Les Paul L/New
Fender Banjo New Condition
BC Rich Bitch - Like New\
3 Jay Turser SG Good Condition
Amps
Marshall vs100 Good Condition
Acoustic 261 very good condition
Boss GT-6 Pedal effects Like New
Old 02-14-2019, 10:34 PM   #5
Another, and IMHO a better option than simply a bolt is an actual shaft assembly with a nut and washer on each side. The TT250 comes with such a thing, and does work on the Hawk. Parts 4, 6, and 7. https://store.cscmotorcycles.com/TT2...RBER-s/353.htm
This design takes all torsional preloading off of the bolt and instead allows it to act as a stud. This makes it less prone to fatigue and failure due to axial loads.
Old 02-15-2019, 07:58 AM   #6
Thanks for the link Dan. Parts ordered today.
Roy
