Old 01-23-2019, 10:42 PM   #1
Allinarush   Allinarush is offline
Rear axel bolt coming loose
I took the Hawk out for a short ride and noticed my wheel not straight. The bolts were pretty loose. Are yall using lock washers or loctite?
Old 01-23-2019, 10:51 PM   #2
Are you talking about the adjusters? If so, I use a washer, lock washer, and then a second nut to tighten against the main one.
Set your alignment and chain tension. Tighten the axle, tighten each adjuster, then spin on an extra nut to each side and tighten it against the first nut.
Old 01-23-2019, 10:55 PM   #3
No, the axle bolts were pretty loose.
Old 01-23-2019, 11:06 PM   #4
There is only one axle bolt. It is the rear axle.
If you aren't sure you understand what I am asking about, post a picture with an arrow or circle around the item you are trying to describe.
Old 01-23-2019, 11:29 PM   #5
You are correct, one axle bolt. Thats the one im talking about.
Old 01-23-2019, 11:53 PM   #6
OneLeggedRider's Avatar
At the moment there isn't enough threads to put 2 nuts on my adjusters so I used loctite. As far as the rear axle I cant imagine it vibrating loose if it's torqued properly to begin with. But I could be wrong.
Old 01-24-2019, 12:16 AM   #7
The rear axle bolt, the one that goes through the swing arm and rear wheel, should have a Stover or Nylock nut securing it in place. The only way that could have come loose is if it was not tightened properly as OneleggedRider mentioned. The nut on the rear axle bolt should be tightened to 35ft-lbs.
Just to be 100% sure we are on the same page. This is the Axle Nut/Bolt.
This is one of the adjusters.
I had to use actual lock nuts on mine, they are about 30-40% thinner than a standard nut. I had to do the same with my stainless exaust studs due to length. I should have bought 5mm longer ones. Hindsight is like that lol.
Old 01-24-2019, 10:44 AM   #8
Lit Hawk   Lit Hawk is offline
Lit Hawk's Avatar
35ft-lbs? I usually tighten mine to 93nm
Old 01-24-2019, 12:02 PM   #9
That's about 68ft-lbs, nearly double what Dan uses.
Old 01-24-2019, 01:23 PM   #10
35ft-lbs is the torque spec provided by CSC for the TT250 Axle bolt. Since the TT250 uses the same basic swing arm and axle design out back, I trust their figures.
It worked on my last bike, and is what I use on the new one. As an added bit of assurance, I always toss a little medium loctite on the bolt.
I have toyed with the idea of drilling a small hole in said bolt for a cotter pin and replacing the original nut with an M14x1.5 castle nut.
Old 01-24-2019, 03:30 PM   #11
Yup, 35 lbs. Much more and you start to crush the awesome box metal swingarm.
Old 01-24-2019, 04:05 PM   #12
Lit Hawk's Avatar
Wow I wonder were I got the 93nm from. No wonder I’ve gone through a couple rear axles and stripped nuts.
Heres the link I got info from
http://www.chinariders.raptorrefuge....d.php?p=198036
Old 01-24-2019, 04:09 PM   #13
Ariel Red Hunter's Avatar
Texas is on the Metric system?..ARH
Old 01-24-2019, 08:04 PM   #14
Lit Hawk's Avatar
This is from hawks owner manual
Old 01-24-2019, 08:26 PM   #15
I don't trust those figures. Why?
It lists Front axle pinch bolt torque.., These bikes don't have front axle pinch bolts. That immediately tells me that those figures are just pulled from some random source.
Case in point, it also says a 10A main fuse yet the glass fuse I pulled from my bike was a 15A. So either their book is right and they installed whatever they had on hand, which in this case would be dangerous, or the book is wrong.
I simply Trust CSC a lot more than the poorly translated chinglish manual handed out with these bikes with about as much care as they are put together.
